laurencen
- Joined
- Feb 19, 2007
- Messages
- 1,211
- Location
- saskatchewan Canada
- Tractor
- Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
so a bit more info, they moved the diesel filler to drivers side and the hydraulic oil filler is now under the box, not a biggie but use to filling on the other side, the response on the go pedal will take some time to get use to, and would appreciate any suggestions on the transition from fast speed with cruise to slowing down, its instant brake, this does need some tome to figure out.
defiantly a must have power tach, beets getting out to lock the attachment, have to install a beacon, looking at the kit it has a grommet, hoping its not drill a hole in the cab, the series A had the wires outside the cab already.
will need some service, the drivers door has a gap of 1/4 inch at the front, im guessing adjustment but tried the bolt the door latch locks onto, its not slotted and there is a bracket this bolt mounts has 2 bolts holding it, loosened them and the bracket does not slide so at a loss how this is adjusted.
