Any Electronics Gurus Out There?
/ Any Electronics Gurus Out There? #81
Some more investigation reveals that the reading between all possible combinations of the four pins shows voltage of 6.5 or 7.5 VDC. These readings DO NOT CHANGE regardless of where the laser is striking the receiver and which arrow is flashing.
There are eighteen receiver diodes at each of the four corners of the receiver "feeding" the five output flashers. The distance between diodes increases, probably exponentially, as they progress away from on grade. It's interesting that when dead center on grade the flasher is at slow rate and when moving even 0.040" off center, the flash rate increases dramatically.
Looks to me that hacking this in an "analog manner" would involve picking up the output from each of the 18 x 4 = 72 diodes rather than the "flashers".
That would be consistent with it being some sort of serial signal, it would be bouncing between zero and one so quickly that the voltmeter wouldn't detect it. An Arduino has interfaces for most of the popular serial protocols, it's not hard to hook it up. The trick is in figuring out which protocol it's using. The easiest way is just to find out from the manufacturer by reading their technical manual. Often times if you look at the circuit board it will say on the board what it is, like "RS232" or "I2C" or "USB." Failing that an oscilloscope will tell but you have to have one and know how to use it.
Unless there were no other options I wouldn't try to read the 72 sensors directly. I suspect there is logic on board that is taking the readings from all 72 and combining and distilling it into a single number. If you read them directly you're giving away that functionality.
I see what you're saying. I wonder, in the scheme of things, whether picking up the flashing frequency of the LED's would be possible? That might be beneficial in knowing how much (or how many) solenoid on time/off time(s) is needed to get to grade level without overshooting.
Edit: A little overshoot wouldn't be such a bad thing, would just need to correct with a little reverse. I haven't ordered a solenoid valve yet but it would be useful even in manual control using a "joystick" for up and down.
Another approach to the means of actuating the cylinder is a power steering valve as shown in the attached. It is a basic Char Lynn four ports; pressure and return and A and B ports to the cylinder.
This type of valve is used on a large percentage of compact tractors and is connected directly to the steering wheel as I'm sure most of you are aware.
I had purchased and mounted this valve just to the right of the other remote valve bank as seen in the pic and done early testing with it to follow the laser receiver. My reasoning is that the rotary motion of the crank input would have the same feel as a steering wheel and the speed of the cylinder can be controlled by speed of the rotation. (The crank next to the seat works favorably from an ergonomic standpoint.)
I've been using one of the remote valves lately while waiting on a detent kit to make it easier to switch back and forth between the Char Lynn and any of the remotes or 3PH. (No power beyond on the Char Lynn)
So what I'm wondering is if it would make more sense to drive the Char Lynn with a variable speed 12VDC motor and worm drive gear reducer. That is how many of the ag tractors have been set up for GPS auto steer retrofits. The DC motor/gearbox output drives the steering wheel by friction around the circumference. Interestingly enough, the manual method of doing this is a GPS light bar mounted on the tractor hood and the operator watches the light bar and steers manually.
The power steering valve has the advantage of being proportional in that the faster you turn it the faster it "steers". So by varying the output voltage and polarity to the DC drive motor we could modulate the response to the laser receiver output.
The steering motors can be bought new in the $400 price range which isn't bad considering they have a built in subplate for the ports. A solenoid directional valve normally requires a subplate for mounting and plumbing.
So what do you guys think? I had kind of forgotten about using the Char Lynn so sorry about not mentioning it sooner.
/ Any Electronics Gurus Out There? #84
I think there's an asymmetry between up and down with a box blade, when it's floating it goes up if you lift it but it's as down as it goes. To make it go down you have to give it more tilt so it digs in more.
I'm afraid you completely lost me on that.
/ Any Electronics Gurus Out There? #86
I'll try again. The way I use the box blade is I have the 3 point hitch lowered to the point where the blade is floating on the ground. If I need to raise the blade I lift up on the 3PH and it raises. But if I need to lower the blade I can't just lower the 3PH more, because it's already floating. The 3PH can't apply downward pressure. Instead I have to change the angle of the blade so that it digs in deeper. My point is that raising is not simply the opposite of lowering.
Sounds like you have a fairly light box blade. Mine will usually stop the tractor in its tracks if I drop the blade too much. The exception would be extremely hard packed dirt and that's when the ripppers are used to loosen things up a bit.
/ Any Electronics Gurus Out There? #89
I think you're better off trying to read the signal directly from the remote out port than trying to read the LED's. Looking at the manufacturer's website it says that the receiver provides power for the remote. So of the four connections, one is power and one is ground. Just need to figure out what the other two are. If it's RS232 one is send and the other is receive. If it's USB one is plus one is minus for the signal.
In doing a little reading on RS232 and USB, my understanding is that USB uses software and an oscilloscope is unable to pick up the data. Is that correct and so would it be nearly impossible to reverse engineer?
/ Any Electronics Gurus Out There? #91
a 'scope can read usb data, but data + and data - lines must both be read, requiring a dual channel [or better] 'scope for it to work..
usb uses uses a differential transmission pair for data. This is encoded using NRZI and is bit stuffed to ensure adequate transitions in the data stream.
the 'scope ground should be hooked up to the usb ground ..
How big of a job would it be for an electronics guru to design and spec all the components required for this system?
/ Any Electronics Gurus Out There? #93
Here's how I would approach it. There's basically three parts: reading in the setting, controlling the blade movement, and the logic to connect the reading to the controlling. I would use a small microprocessor like an Arduino or a Raspberry Pi.
Reading: if the signal between the receiver and the remote is a standard protocol, both Arduino and Raspberry Pi have built-in processors for USB, RS232, I2C and other protocols. Reading the data is just a matter of connecting the right pins on the receiver plug to the right pins on the microprocessor board.
Controlling: Two ways of controlling the blade have been proposed, either using an electric hydraulic valve or using a power-steering type valve with a DC motor. The electric valve is not difficult, it just needs to be attached to one output pin of the microprocessor for up and another output for down. If the current or voltage requirements of the valve are different from what the pins can provide there needs to be an appropriate relay. Controlling the power-steering type valve is done by controlling the speed of a DC motor. This is commonly done by a technique called pulse width modulation, where pulses of electricity are sent to the motor, the longer the pulse the higher the speed. This requires attaching a single output pin of the microprocessor to the motor. Again, if the voltage or current requirement of the motor can't be met by the microprocessor pin a relay is necessary. If you were to take a course in using Arduinos or Raspberry Pi this is all stuff you would learn in the first month.
The third part is the control logic, this is a program that runs on the microprocessor. This is the big wildcard. It could be as simple as "once a second, read the blade height. If it's too low raise it, if it's too high lower it. Repeat." Or it could be that you need to keep track of the history of the blade height and the history of commands you've given and adjust your response based on what's working. Or maybe you need the user to input some information about the hardness of the soil. Or maybe you need another sensor to tell you the speed of the tractor.
The control logic will take some trial and error, a lot of time just driving across fields and watching what happens. The reason I'd prefer Raspberry Pi for this, even though I have more experience with Arduino, is the RP has more capability for things like logging data and giving a display while it's working. If you were to do this with Arduino you'd probably have to have a laptop on the tractor with you while debugging log what's happening. I've also done projects like this where I had an Arduino-like device attached to the USB port of a smartphone and the phone provided the display and logging.
Thanks again for your extensive input! I don't have the knowledge but I'm sure that you and a couple others who have been responding are more than capable of making this work.
I see some advantage in the DC motor approach. The rpm could be controlled as needed depending on how far from the target as well as acceleration and deceleration for smooth operation. I keep thinking that PID could be utilized as well for "learning on the go" but may just add unnecessary complexity. Just about every closeup I see of the control box on the tractor has a sensitivity knob and I suspect this is in response to ground speed. With that said, I still feel that a solenoid valve could be made to work
I don't believe, in my mind at least, that the hardness and type of soil would be needed inputs. The height needs to be adjusted if the receiver is showing off grade and the operator needs to adjust tractor speed to that which the control system and sensitivity adjustment can consistently respond well.
I've noticed that some of the ATV pulled small box blades use 12 VDC linear actuators to raise and lower the cutting edge. That would take a level of complexity out of this project but doubt whether a "normal" alternator and battery would come close to powering a BB of any size in an auto grading app. I'm guessing that an oversized alternator and battery combo might work but not sure. Anyone have experience along those lines?
Many of the linear actuators have built-in limit switches. Duty cycle might be another consideration, I'm guessing.
/ Any Electronics Gurus Out There? #96
I am sure that the duty cycle would come into question. That could be going up and down constantly appoaching grade.
/ Any Electronics Gurus Out There? #97
The reason tractors use hydraulics is that hydraulic has the advantage when you need to transmit a lot of power. Transmitting 1 HP for a hydraulic system is easy. For a 12V electric system you need about 60 amps to do that. That would require a #6 wire, but also in the windings of the motor or actuator. That would be a big, heavy, expensive item -- if your tractor electrical system could handle it. Electric is good for moving small items around but not something like a box blade.
Thank you. Points taken.
Thinking about the linear actuator got me going again. :) I have a linear actuator mounted on the box blade as shown in the pics with up, down, speed control and remote readout on the tractor. The idea is to take grid readings of the elevation of a work site prior to grading. This is to calculate cut and fill and finished grade elevation and it would be a manual process by moving the rig to the next location on the grid, raising or lowering the receiver to take a laser "hit" and then recording the reading on the remote readout at that location. Then rinse and repeat.
With an automated setup for grading the same electronics that control the blade height could be switched to and used to automate the surveying process mentioned above. The process would be driving to each grid location with the linear actuator energized by the auto control so it would elevate to follow the laser beam. The blade height would be clearing the ground by several inches and the cylinder wouldn't move during this process, only the actuator which is DC motor driven.
The digital readout I have mounted on the linear actuator would give the continually changing elevations to the operator's remote while driving and could be recorded statically at each grid point. The GPS coordinates could also be recorded at that point but that's another story.
/ Any Electronics Gurus Out There? #99
I've been experimenting with differential GPS. The idea is that GPS is accurate to within about 20 feet at best. For the most part the error in GPS is due to variation in atmospheric conditions, so if you put two GPS receivers side by side they will both read the same. With differential GPS you use two receivers, and put one of them at a fixed location. By subtracting the reported location of the fixed one from its known position you get the local error. You then add the local error to the reported position of the mobile one. If all you care about is relative position you don't even have to know the actual location of the fixed unit.
This is the unit I've been using: C94-M8P | u-blox The units are $400 each and you need two. I've found that I can typically get accuracy to within a half inch with these. The hitch is that there has to be good GPS reception, which means line of sight to the entire sky. Trees or buildings blocking the sky degrade the results.
I could see a couple of ways of using these in conjunction with the laser level. The first is mapping. Drive around the field and every few seconds log your location and elevation. The second would be in creating more complex contours. You could draw out a contour map of how you want the land to look. Then as you drive around the GPS tells the computer the current location, the computer looks up the desired elevation, reads the current elevation off of the blade, and adjusts the blade accordingly.
Next step would be to eliminate the operator altogether...
That is very interesting stuff! The farmers are using RTK, as I'm sure you know, for sub inch auto steer accuracy, but it comes at a much higher price than $400/$800. One of the local RTK installations (Real Time Kinetics) has the base station mounted atop the local "high rise" grain elevator to cover a large portion of the valley. The good thing is that several farmers can share one base to minimize cost for auto steer and other GPS apps . I think there is a pending market for consumer grade auto steer for lawn mowers and fertilizer spreaders. (Not sure how the robo mowers work) A GPS controlled lawn fertilizer applicator with auto shut off is not far fetched, in my opinion.
I'm an old machinist who became acquainted with NC (Numerical Control) back in the late sixties in a machining environment. We used punched tape to control the milling and drilling of holes etc as there were no micro computers back then. It later morphed into CNC (Computer Numberical Control) and prices stated dropping dramatically to the point where hobbyists could afford it. CNC wood routers are common today and I have used mine extensively for producing components for the Palen Archtop Guitars shown at the link below. (Shameless plug but I actually quit building them in 2012.)
What I'm getting at is there seems to be a corollary between the CNC and GPS that keeps popping up for me as time goes on. You mentioned "Drive around the field and every few seconds log your location and elevation" and that is basically what I did to one of my hand carved archtop back and top plates to get it into electronic format. The archtop plates start out about 1" thick and end up as a carved contour about 3/16" thick. Digitizing the carved plate (spruce or maple) involved mounting an electronic probe into the spindle of the CNC router and traversing the entire surface in a grid of points about 1/16" to 1/4" apart and taking elevation readings at each. This created an electronic file that could be read into the PC creating a point cloud and generating a surface in turn. This surface could then be viewed on the screen and tweaked as desired and even a solid model could be created.
Sorry to ramble but but it seems that there is a tremendous opportunity out there for consumer grade GPS apps.
Edit: Forgot to mention that the CNC router could then be used to machine subsequent parts eliminating much of the labor intensive hand carving.
2016 Chevrolet Silverado 1500 Pickup Truck (A61568)
2016 Chevrolet...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
John Deere 7000 Planter (A63109)
John Deere 7000...
2018 John Deere 470G Hydraulic Excavator (A61567)
2018 John Deere...
2015 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61568)
2015 Globe Trailer...
New/Unused Landhonor 11ft x 19ft Carport with Open Side Walls (A61166)
New/Unused...
