Todays shop time.
/ Todays shop time. #921
She's a Beauty Dragoneggs did you get to run some test pieces through it yet? How is the set up from the factory ? Most new equipment needs some tlc. There is a good video by the wood wisperer on utube on that exact model check it out.:drink:
Thanks spitter. I did watch the video just before pulling the trigger. I don't have a good straight edge that I can depend on though. Got a 36in on order. Going to make a few test cuts today and do some measuring. Then maybe I can have a reference point before/after tuning.
/ Todays shop time. #922
FB1FED9B-A3FC-41C3-9AE9-A353FE53B740.jpeg1159D404-F9C7-48FA-A31E-A76412B41685.jpeg5A516632-A393-433C-B270-42EB6F54C42A.jpeg1D5BD912-989C-4985-86D1-E05EC98C1DCF.jpegA new shop acquisition a couple months ago. This is a South Bend Lathe originally born in the 1920s or 30s as a Lin痴 shaft driven metal lathe. I have no idea about it痴 life history other than my late neighbor owned it and used it as a wood lathe for a number of years. I acquired it out of his estate and spent some time tuning it upl making it presentable. You got to love old iron. This machine weighs in somewhere around 1,500# and is still dead nuts on the money with no spindle runout. Currently powered by a
1 1/2 HP DC variable speed motor
B. John
/ Todays shop time. #923
Looks like someone stripped all the goodies off to make a dedicated woodworking lathe.
/ Todays shop time. #924
That is exactly what happened somewhere in it’s lifetime adventure.
However, it’s a rock solid wood lathe and light years better than the old Dunlap (Sears) lathe my dad had back in the 50s.
It came with three ‘Nova’ chucks and a variety of faceplates, three jaw chucks, chisels, and other stuff. Regretfully the last owner was in poor health and passed away two years ago so the machine wasn’t used for at least five or more years and was left in an unheated, wet barn. It’s incredible the damage humidity and condensation can do.
B. John
/ Todays shop time. #925
No pictures yet but I've been making a traction bar for my Ford Ranger, have most of the pieces cut out at this point, some of them mounted to the truck but at least a couple more evenings of work left to do... I tell ya, a plasma cutter, bench grinder and a slew of angle grinders (I've used 4 different ones on this project so far, each with different attachments) makes some things happen...
/ Todays shop time. #926
Little fun project that's been bothering me, the air cleaner adaptor on my zero turn is plastic and collapsed from the clamp holding the hose on.
Have been doing some maintenance on the mower and finally decided to fix it, was hoping I had some pipe that was close to save on machining time bit no luck.
Found some nice 2" mystery stainless TGP solid round and machined a backup ring.
Works good and now the dirt doesn't have way to bypass the filter!
/ Todays shop time. #927
Nice $250 fix!
/ Todays shop time. #929
Nice looks good
/ Todays shop time.
A member was asking questions about my brush guard and you can’t send pictures in a PM or at least I haven’t figured out how so I decided to post here. It’s a heavy piece of woven rod which is way overkill for the task. I found it in a junkyard so I have no idea what it started life as. Luckily the M59 brush guard is pretty straight because I couldn’t have bent it across a curved one. I intended for it to have a bumper to protect the tie rod but I mis calculated that and had to cut most of it off. Whenever I get around to it I’ll weld another piece on that’s bent to clear the tires. IMG_8547.JPGIMG_8548.JPGIMG_8549.JPG
/ Todays shop time. #931
A member was asking questions about my brush guard and you can’t send pictures in a PM or at least I haven’t figured out how so I decided to post here. It’s a heavy piece of woven rod which is way overkill for the task. I found it in a junkyard so I have no idea what it started life as. Luckily the M59 brush guard is pretty straight because I couldn’t have bent it across a curved one. I intended for it to have a bumper to protect the tie rod but I mis calculated that and had to cut most of it off. Whenever I get around to it I’ll weld another piece on that’s bent to clear the tires. View attachment 649975View attachment 649976View attachment 649977
Looks like screen deck material from a vibratory screener.
/ Todays shop time. #932
A sad day in my shop today. Just sold my dad's 1964 10in Craftsman Radial Arm Saw and stand, including a vintage dado kit specifically for it. The dado kit still had the Sears price tag of $29.95. That was a lot of money back then!
I helped (as a kid) build a cabin with it, where I spent many summers. Haven't used it in more than a decade and needed space so... now headed to a place where it will get some attention. I feel bad. Sort of like putting a pet down. The money didn't matter. Am I being ridiculous?
/ Todays shop time. #934
No, your not being ridiculous. That had to be hard. I still have a wooden handled screwdriver that was my dads. It’s junk but I wouldn’t take 1K for it.
/ Todays shop time. #935
Not ridiculous just sentimental. Take some other smaller tool out that reminds you of him. Funny how we can get with inanimate objects like the van I owned for most of my kids lives. They grew up in it so it had fond memories. It's the memories we need to keep a hold of.
/ Todays shop time. #936
Not ridiculous, it's very difficult to part with dads stuff.
I have about 6 cubic feet of reloading stuff of his. It's old stuff that was mostly bought at garage sales but it was his.....
/ Todays shop time. #937
Been a couple of days. I got check valve installed on toplink cylinder. Check valve had 12 mm tube fittings. Cylinder had 9/16 ORB fitting. Put hydraulic pipe fitting in to 1/4" npt. Made an adapter for 12mm to 1/4" npt. Cylinder now stays where I put it.
/ Todays shop time. #938
Wow makes me feel old. I have that exact same saw and dado set. The first big tool I bought after we got married. Still use it.
I have a ton of my dad's and grandfather's tools I can't part with. I know how you feel. Who needs 3 wooden levels ??????????
gg
/ Todays shop time. #939
Nice adaption, I have the same valve for my side link that I've been putting off adapting because of the metric adaption and tight fit.
Luckily I bought a top link with a lock valve back when I put it on so I don't have to adapt that one.
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
2020 Elgin Pelican Street Sweeper (A64194)
2020 Elgin Pelican...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2020 Freightliner M2 106 Johnston VT652 Sweeper Truck (A64556)
2020 Freightliner...
2015 International ProStar T/A Day Cab Truck Tractor (A64556)
2015 International...
2017 Freightliner M2 106 TMA Attenuator Truck (A64194)
2017 Freightliner...
