4500z traction control lever Jammed
/ 4500z traction control lever Jammed #1
Andy2dotO
Central California
Ventrac 4500Z
Just finished mowing some of the higher-angle slopes on the property, and noticed things got a little squirrely on my last trip down.
Got to level ground to clean the tractor and noticed that traction control was jammed at zero. I cannot move the lever to save my life.
Anyone had this happen? I am hoping I am just being dense instead of having to take this to the dealer.
Any pointers are appreciated.
Thanks!
/ 4500z traction control lever Jammed #2
Thanks!
Yes, mine did the same thing, they put these huge washers on it and they bind up. I removed them and put it back together and never had a problem since... If you look down inside where the spring is attached on the left front..... jim
Aha! Right you are, Jim! I fiddled with the lever and the washers and *bam* fixed.
Had to stand on my head and spit nickels to get the index plate back in there after adjusting, but once that was in, back in business.
Thanks, Jim!
/ 4500z traction control lever Jammed #4
Thanks, Jim!
That was a engineering screw up from Ventrac, glad to see it worked out for you.... I'm dealing with an other one the stump grinder, I should have got the one from Steiner..... you can see it... lol.. jim
Oh. Whats doing with the stump grinder? Mines been working like a charm, but its fairly new.
/ 4500z traction control lever Jammed #6
first is the stupid mirror, what a way to work. Steiner sets theirs off to the side a little more and you can see it. Also the stand, and trying to put it on, that is the best they can do? I rented one first, I should have known better..... but I got a real good deal on one ... LOL...
2007 Mack CV713 Granite Truck, VIN # 1M2AG11C37M043941 (A65563)
2007 Mack CV713...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
500 BBL FRAC TANK TRAILER (A65643)
500 BBL FRAC TANK...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
2022 EZ-GO ELITE...
2019 HINO 268 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 4X2...
