4500z traction control lever Jammed
   / 4500z traction control lever Jammed #1
Andy2dotO
Central California
Ventrac 4500Z
Just finished mowing some of the higher-angle slopes on the property, and noticed things got a little squirrely on my last trip down.
Got to level ground to clean the tractor and noticed that traction control was jammed at zero. I cannot move the lever to save my life.
Anyone had this happen? I am hoping I am just being dense instead of having to take this to the dealer.
Any pointers are appreciated.
Thanks!
   / 4500z traction control lever Jammed #2
Thanks!
Yes, mine did the same thing, they put these huge washers on it and they bind up. I removed them and put it back together and never had a problem since... If you look down inside where the spring is attached on the left front..... jim
Aha! Right you are, Jim! I fiddled with the lever and the washers and *bam* fixed.
Had to stand on my head and spit nickels to get the index plate back in there after adjusting, but once that was in, back in business.
Thanks, Jim!
   / 4500z traction control lever Jammed #4
Thanks, Jim!
That was a engineering screw up from Ventrac, glad to see it worked out for you.... I'm dealing with an other one the stump grinder, I should have got the one from Steiner..... you can see it... lol.. jim
Oh. Whats doing with the stump grinder? Mines been working like a charm, but its fairly new.
   / 4500z traction control lever Jammed #6
first is the stupid mirror, what a way to work. Steiner sets theirs off to the side a little more and you can see it. Also the stand, and trying to put it on, that is the best they can do? I rented one first, I should have known better..... but I got a real good deal on one ... LOL...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
5' MOWER (A52706)
5' MOWER (A52706)
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
