wiring 3rd function power
/ wiring 3rd function power #1
alabamatoy
Somewhere, Tennessee
An orange one
Installation instructions tell me to wire directly to battery. Seems high risk...a hat thrown over the lever or a child climbing on the tractor could fry my battery and/or solenoid. Late model L3901 Kubota... which circuit should I tap to get power only when "ignition" is on? Suggestions appreciated.
/ wiring 3rd function power #2
Does the key switch have a accessory terminal , you also need a fuse.....
I will check that, thanks. I completely understand how to wire the solenoid switches....depending on the solenoid amp draw, I may even need a relay....I just wanted to find a circuit to tap that would be dead when the machine is not powered up.
/ wiring 3rd function power #4
My kubota also has a off/on button to power the switch on the loader joy stick.....
Well, I suppose that's one way to skin the cat. It would reduce the risk of someone wankering the battery or the solenoid. Hmmm....
/ wiring 3rd function power #6
It lights up green when on just a round push button.....
/ wiring 3rd function power #7
I have a cabbed tractor and I tied the 3rd function valve into the pre-existing radio circuit. I have no plans for a radio so the pre-wired and fused circuit was very handy for me to use.
/ wiring 3rd function power #8
I have mine wired to the battery. I have no issues. Who is going to hold down a momentary switch long enough to be a problem.
/ wiring 3rd function power #9
/ wiring 3rd function power #10
Hard wire to the battery with a fused circuit and a relay for the high amp draw. Power the relay from any low amp circuit available that is "key on".
Kubota's pushbutton switch on the joystick is to disable the 3rd function buttons so you aren't accidentally activating them if you are doing standard loader bucket chores or a set of forks for example.
/ wiring 3rd function power #11
The working side of the relay wire in a fuse straight to battery. The control side of the relay go off of something switched with the ignition on like the radio or something. Fuse the control side with a 3 or 5amp fuse.
/ wiring 3rd function power #12
But it's switched. No power when the key is off.
Correct ,No power when key is off I just shut the power off if I have forks,bucket on in case you hit the switch its not trying to pressurize the lines.......
/ wiring 3rd function power #13
Yep. The OP is trying to figure out how to wire it so it's dead when the key is off.
Metal Bigfoot Lawn Art (A61569)
Metal Bigfoot Lawn...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A60352)
2025 Wolverine...
2012 Travis Body & Trailer Trailer, VIN # 48X9R5323C1007837 (A61165)
2012 Travis Body &...
Snap-On Zeus Diagnostic Machine (A63118)
Snap-On Zeus...
2000 KOMATSU GD530A-2CY MOTORGRADER (A62129)
2000 KOMATSU...
2025 Swict 66in Bucket Skid Steer Attachment (A61567)
2025 Swict 66in...
