Loading a Tri-axle dump with L47/M62
   / Loading a Tri-axle dump with L47/M62 #1
JK10MF1635
Member
Northwest CT
Massey Ferguson 1635
I was hoping someone may have done this or tried to do this. I知 looking at both the Kabota L47 and M62. One question I have is can either of these load a tri-axle dump truck with the FEL? I have searched and googled and not come up with anything in that regards. The 47 dumps at 9.5ft and the 62 at 10.5 feet. I致e googled the height of tri-axle beds and come up with over 9 feet and over 11 feet high sides. So has anyone actually tried or done it? I have a lot of material here that I need hauled away and I知 wondering if one of these machines would allow me to do it myself. Thanks for any help.
   / Loading a Tri-axle dump with L47/M62 #2
I have done it successfully in my tri axle and my high sided single axle with an L-35 and L-39 while loading fill dirt and stone.
It was a pretty close call though. I made the situation easier by building a 1-2 foot high earthen ramp on the loading side of the truck. Problem solved. However, I dont know what youre loading.
I have about a 250x16 ft paved driveway that needs redone and I need to haul all the old asphalt out after tearing it up. I estimated like 30 loads in my 14,000 lb dump trailer. No way I’m doing that. It’s cheaper calculating my time if I load the tri-axle that dumps the process to haul it to their location than me doing it with my truck and dump trailer. I need to be able to load the tri-axle though.
   / Loading a Tri-axle dump with L47/M62 #4
I load my single axle dump with my M59. I don’t think there’s much difference in bed height with a tri axel. IMG_7955.JPG
   / Loading a Tri-axle dump with L47/M62 #5
   / Loading a Tri-axle dump with L47/M62 #6
I have a L47TLB and I drive a tri axle dump , To small never get the asphalt in the middle of the truck some dump bodies have 50'' side walls plus the tire height and sub frame.......
   / Loading a Tri-axle dump with L47/M62 #7
That’s even better. Take some old asphalt and stack it up to make a loading ramp. Dirt I was using tended to get all rutted up.
   / Loading a Tri-axle dump with L47/M62 #8
I guess I would go find the truck(s) I was going to have to load and see how tall they are.
   / Loading a Tri-axle dump with L47/M62 #9
Do like Haydude suggested and just build a dirt ramp tall enough that you can climb up to dump the load over the side into the trailer.
Spread or haul off the dirt after you're done.
   / Loading a Tri-axle dump with L47/M62 #10
My suggestion would be to just rent an excavator with a thumb. That will do a much better job of ripping the old asphalt out, AND loading it into a truck...whatever size truck you use.
I find with a tractor, I use it for 95% of the work I need to do, but for some specific jobs, it is just easier to rent a specific machine, for a specific job.
UNUSED FUTURE FT-LJB12 POLYTHYLENE BOARD (A57193)
UNUSED FUTURE...
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
1844 (A57192)
1844 (A57192)
Adams 5T Pull-Type Fertilizer Spreader (A57024)
Adams 5T Pull-Type...
2003 Big Tex 10PI...
