L4310, add float function to FEL
/ L4310, add float function to FEL #1
hoffmtc
Member
Kubota MX5200 HST
Using the new-to-me L4310 this past weekend and I realized that this tractor's front end loader does not have the float function.
Is that a control valve block that can be replaced to include the float function?
/ L4310, add float function to FEL #2
I’d be surprised if it didn’t have it already. Sometimes it can be hard to engage especially if the previous owner never used it.
I can try again, but sure didn't seem like it wanted to go....
Tractor was made in 2000 I believe. When did they start with the float valves?
/ L4310, add float function to FEL #4
Try pushing the loader handle up should stay locked up in float
/ L4310, add float function to FEL #5
The float on my old L4630 would only engage if I held the lever forward. I never attempted to diagnose the issue which was likely in the valve body.
/ L4310, add float function to FEL #6
" When did they start with the float valves? "
I believe it was when they made the 1st loader.
" I never attempted to diagnose the issue which was likely in the valve body."
The float control is in the can at the end of the spool, not the valve body.
I believe my tractor has the LA681 loader. Here is the diagram for the control portion of the LA681.
Kubota LA681 (FRONT LOADER) Parts Diagrams
So if my lever does not want to 'float function', I should be checking the can(s) at the bottom of the block?
thanks for the info!
/ L4310, add float function to FEL #8
Go to the CONTROL VALVE [COMPONENT PARTS] look at parts A you well see 5 balls and 2 springs one for the balls and 1 to put in N.
Most of the time it is just rusted and dirty, could be a broken spring. If you take it apart make sure you watch out for the balls, maybe wrap a rag around it catch them. The bigger ball push the little one out, just in case you get mixed up. Have at her!! easy fix.
/ L4310, add float function to FEL #9
MY 1974 JD 2030 with JD 245 loader has float. Yours should too.
Thanks for the tips! Good to know that I have a function I like to use, just needs some attention.
Do you lose much fluid when taking this apart?
/ L4310, add float function to FEL #11
NO fluid.. just watch out for the little steel balls and springs....
I stopped out at the land yesterday where the tractor is located. I didn't have time to tear into this yet, but see the components I need to inspect and clean.
The loader lever solidly does NOT want to go into float detent. Can disassembly and cleaning be done without removing the entire valve assembly from the tractor?
Thanks for the info and assistance!
/ L4310, add float function to FEL #13
Yes you can. On the bottom of the valve, you're see two caps. One should be longer than the other.
The longer one is the float spool. Be careful taking the cap off because often a couple of small balls and springs will pop out. You don't want to lose that.
/ L4310, add float function to FEL #14
Here is a quick video of a detent rebuild , should give you some idea of what to expect.
Detent - YouTube
Yesterday I finally had time to look at this a bit. Thanks to the tips provided, I had a baking ban under the assembly for catching the ball bearings as the fell out...
Lots of corrosion, the spring was broke in half, and the larger ball bearing was encased in 3/16" of solid corrosion in the bottom of the tail cap! No wonder why the float position wouldn't work....
So while I'm waiting for new parts I put the assembly back together without the 4 smaller ball bearings, without the larger ball, and without the spring.
Float function will work by holding the lever up, but now I noticed that the lift function is very slow. Will that return to normal once I get the new parts installed? Or did something else happen?
Finally got around to fully tearing into this for repair. Really corroded in there, the old 'ball holder' part fell apart trying to unscrew it. I think they put loc-tite on that from the factory too. But I finally did convince it to come out. New rebuild kit with all new lower end components, springs, ball bearings, caps, etc.. was $114. But that price was worth it to have my detent float function again, and nice smooth operation. All went together nicely and works great. I used some grease in the new parts and balls, I don't store the tractor outside and don't plan on using it in the rain much so it should be good for a long time. Thank you to those that chimed in!
/ L4310, add float function to FEL #17
Nice.........:thumbsup:
Very helpful to put a dark tarp down under the tractor and make a flat section with built-up sides under the area where you are working. If you happen to drop any parts or balls, with clumsy big hands like mine, it sure does save some searching and lots of bad words said. Everything stays contained and easy to find if dropped. Also putting some grease in the center spring and small ball holder areas really helps when re-assembling, it keeps things "stuck" together nicely.
/ L4310, add float function to FEL #19
When buying ahead for a job like that, (for me was the rear quick couplers on my JD 2030) I buy a couple of the balls too, since I know I will drop/lose some.
2013 Ford Escape SUV (A61569)
2013 Ford Escape...
2010 Volkswagen GTI Hatchback (A61569)
2010 Volkswagen...
2023 Chevrolet Express Van, VIN # 1GCWGBFP8P1104620 (A61165)
2023 Chevrolet...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
6x12 Leonard Utility Trailer (A61165)
6x12 Leonard...
