Chipper Chipper/shredder questions, exploring what I can do with them
   / Chipper/shredder questions, exploring what I can do with them #21
When I want to use the chips somewhere I've chipped into the back of my UTV, using a tarp over the roll cage as a backstop and to keep most of the chips out of the cab.
I got an ATV/UTV dump trailer from Woodland Mills which is what I chip into now. It does mean two trips or two people.
A few chippers have hitch receivers. Or if you can weld you can add one.
I use the chips on my dirt roads and in the chicken pen. Sometimes they go into the compost bins but we're usually ok there from other sources. Mostly I spray them out on the ground where I'm chipping to enrich the soil.
I leave the old rotting wood in the woods. If it's in the way I move it with the grapple otherwise it stays where it is. If it's rotting then it's on its way to becoming soil, and they're habitat for critters. From a fire safety standpoint rotting wood on the ground is not much of a risk.
Between air quality regs, lack of safe places to do it and a summer dry season that lasts 7 months it's not practical for me to burn. If you can safely and legally burn piles you might consider that. There's some stuff that I won't chip- old rotting wood and poison oak- which go on piles to rot. Obviously you would not want to burn things like poison oak.
Around here rental chippers cost a lot and it's an hour + to town and back when I pick up a rental. If you're renting you have time pressure to get your money's worth. With my own chipper I can do a hour's worth or whatever I need and then go back to cutting. OTOH rental trailer chippers can have more capacity. I've been able to chip material close to the chipper's 8" capacity but I have to throttle the feed way down and turn the feed on and off. With 50-something hp instead of my tractor's 37 you'll have less of an issue with that. Most people use material that large for firewood. Now that I have a decent stove I'm chipping less large stuff.
   / Chipper/shredder questions, exploring what I can do with them #22
Or just hire it done and have it finished in a few days.
   / Chipper/shredder questions, exploring what I can do with them #23
Many good points. The Wallenstein has a clam shell type enclosure - easy access to the enclosure to unplug stuff & access to the knife blades. The enclosure splits in half - hinge on one side - containment bolt on the other side. Undo the containment bolt - lift the top half of the enclosure and tip to the hinge side.
Punky/rotten wood will "chip". Don't expect nice clean chips from this wood. Lots of wood dust and shattered chips.
Hardwood, softwood, green wood, wet wood - all will chip just fine.
Really "sappy" wood - freshly cut pine - can tend to plug the chute. I had quite a bit of problem with this and my green pine trees and the Wally BX42S. Solution - identify, fell, drag to pile, wait a year to chip. So - every year I was chipping last years trees. Then - ID, fell, drag to pile for next year.
I do not have this problem with the BX62S. Higher air flow, larger chute diameter.
   / Chipper/shredder questions, exploring what I can do with them #24
Bull, most chippers you can adjust the bed plate/knife clearance to chip any size. I have mine set fine because I sell the chips and most people want small stuff. Nova Tractor sells the chipper. It seems to be a good one. I had a small Troy-bilt chipper/shredder, Jinima chipper and a Wood Max wm8m, they were all too much work and high maintenance. This one will chip circles around them. Most of the trees around here are Juniper, they have a loose shaggy bark that collects dirt when the wind blows, very hard on chainsaw chain and chipper knives. I use to burn my trimmings but that is such a waste, I chip everything now that wont make firewood.
Do your research on chippers, they are not all created equal. Just for your info, here is a roller bearing/roller frame comparison, note light duty v/s heavy duty. Also be sure and get the clam shell type flywheel housing, way easier to change knives then going through an inspection cover.
When I do a large chipping session I use my dump trailer and with a small area with a lot of moving I chip into my Bobcat loader bucket.
Thanks for this post. I copied and saved and then looked up the BX52: only $1500. Really good buy and good to hear about ease of maintenance. Could be a good replacement for the ole Mac.
Ralph
   / Chipper/shredder questions, exploring what I can do with them #25
   / Chipper/shredder questions, exploring what I can do with them #26
Out of curiosity what do they charge in your area? I'm looking at clearing some fence lines and burning has its own headaches.
I had a couple thousand trees removed over 4 areas separated by rows of good trees. The rows and spacing was a grid, a tree every 7 feet. The trees were about 10" on average and 30' tall. About 3 days work for $23k. Many times the feller-buncher would cut and grab 3 trees before laying them down. The cut/grab only took 1-2 seconds. The hydro-ax ground up anything sticking out of the ground like Buckthorn.
   / Chipper/shredder questions, exploring what I can do with them #27
I have 1 acre of dead. trees I wish I would have called someone with a mulcher and had them clean it out I must have cut down 100 dead ash trees and burned them I am still gonna rake the limbs and pieces of wood and burn I am almost done at least it was good exercise.
   / Chipper/shredder questions, exploring what I can do with them #28
I have a half acre and house in Northern Virginia that I rented out and it grew up in mixed hardwood saplings, brambles and bamboo over about a 25 year period.
Couldn't walk through it.
Finally in 2012 I moved the renter out and my son and his family in.
My choices for clearing [NO BURNING ALLOWED] were pay -estimates were in the thousands, mostly labor -, cut and haul - a fee of about $15/pickup load and a 40 mile drive, cut and have them haul, county hauls - $100/load, rent a chipper for about $800 a week.
Plus I've several hundred acres in Mississippi I'm building trails on.
Renting is often a non-starter - rainy periods, schedules etc. are a pain
So I bought a Jinma 8" chipper for about $1600 (w/ spare belts and blades) and my son and I cleared and chipped it over the course of a spring and summer.
Then I hauled it down to Mississippi.
It was well worth it to me. I've only used it a few time since but it's there.
But it ages well in my shop.
I have a lot of ash, and it's probably a question of when, and not if, the emerald ash borer infestation in New England gets them. That will be a sad day, hope I don't live to see it but it looks grim. Is that the source of your dead ash?
   / Chipper/shredder questions, exploring what I can do with them #30
Yes sir it was real nice back there but the ash bore killed all of them the farm behind me has thousands of dead ash trees I still have cedars back there.i am fortunate to live in a beautiful area.but these same ash bores will probably travel up to your area unfortunately.
   / Chipper/shredder questions, exploring what I can do with them #31
Lots of things besides the EAB have/are killing ash. Only a matter of time till they are gone.
I have been selectively cutting and selling the better trees to a tool handle mill for top dollar before they die to at least get something out of them.
The poorer quality and dead ones go into the firewood pile
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
(INOP) JLG E300AJP ARTICLATED MANLIFT (A60429)
(INOP) JLG E300AJP...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
Enclosed Service Truck (A55788)
Enclosed Service...
Cat CB24B (A60462)
Cat CB24B (A60462)
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
