Installing Land Pride 3rd Function on L3301 with backhoe
   / Installing Land Pride 3rd Function on L3301 with backhoe #11
This helped me so much. I have been trying to figure this out for 2 days. My Kubota dealer didn't really know for sure how to do this without adding some tees. You really need to make a youtube video of this because there is practically nothing on the web on how to connect a third function if you have a back hoe on the tractor. Again thanks
   / Installing Land Pride 3rd Function on L3301 with backhoe #12
Are there any limits on the operation of this 3rd function? I have been told that the electrically actuated valves (solenoids) such as those used in this kit have some severe limits on duty-cycle, but I cannot find any citation or basis for that. So, for example, a front-loader style hydro-powered snowplow would not be usable because its constant 3rd function flow would burn out the solenoid on this kit.
   / Installing Land Pride 3rd Function on L3301 with backhoe #13
You can use a power angle plow , grapple, 4in1 bucket , But not a hydraulic motor like a post hole digger something that has to be on all the time
   / Installing Land Pride 3rd Function on L3301 with backhoe #14
Hmmmmm.....a PHD was exactly why I wanted the 3rd function, based on this Messicks youtube video -2XRRoSth_8 (Sorry, this wretched site wont let me post a link) Actually, the PHD and a grapple. Is using a PHD really a problem, the duty cycle is that short?
   / Installing Land Pride 3rd Function on L3301 with backhoe #15
Our valve is made for momentary use like open / close or left / right operation. It is not made for rotary implements like augers. The valve has a extremely tight tolerance and if held down to use a rotary attachment it will heat up and swell causing the valve to seize. Thanks!
-Josh Nabb, W R Long, Inc.
   / Installing Land Pride 3rd Function on L3301 with backhoe #16
I just got a call from Messicks. Seems that they might be gonna revisit the video I cited. The service guy stated that they do not recommend using the Kubota 3rd function with an auger....even though the referenced video clearly shows them doing so.
   / Installing Land Pride 3rd Function on L3301 with backhoe #17
Do you have a rear remote?
   / Installing Land Pride 3rd Function on L3301 with backhoe #19
I do not. Im interested if this is a potential solution!
You could add it and run your post hole digger or do you have a backhoe ,You could use those lines add a valve for the post hole digger
   / Installing Land Pride 3rd Function on L3301 with backhoe #20
I run my plow & auger of the OEM 3rd function valve on my L4060HSTC. The plow is only very momentary intermittent usage, as a grapple would be. I havent done a lot of PHD work, but no issues yet. It's about a 1 minute on, 1 off duty cycle.
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
2003 Big Tex 10PI...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
Enmark Z Spray (A53316)
Enmark Z Spray...
Yamaha (A55758)
Yamaha (A55758)
John Deere 5105M (A53317)
John Deere 5105M...
