Installing Land Pride 3rd Function on L3301 with backhoe
   / Installing Land Pride 3rd Function on L3301 with backhoe #1
ProjectKing
USA
Kubota L3830 FEL, Kubota L3301 FEL/BH, Ford Golden Jubilee, Honda Foreman 450ES, Polaris Ranger 400, Kubota ZD326, etc, etc
Hello,
I'm nearly ready to order a Land Pride loader 3rd function kit for my L3301. The valve kit number is #380-152A.
The instructions only cover a tractor with loader. The instruction do not apply to tractors with loader and backhoe. Mine has a backhoe (BH77).
Sooo does anyone have instructions or advice on how to install kit on a tractor with a backhoe?
Thank you!
   / Installing Land Pride 3rd Function on L3301 with backhoe #2
Mine has the landpride 3rd function and BH77. I'll try and take some pics of the hose routing tomorrow. Just off the top of my head I believe the power beyond goes back to the backhoe first then to the loader and then to the third function all in series. I believe you'll need a new PB hose though because the landpride kit comes built for loader only applications only as far as I know.
Awesome! Thank you! How do you like the Land Pride 3rd function?
   / Installing Land Pride 3rd Function on L3301 with backhoe #4
It's great, very comfortable handle and buttons. I tried out the wr long 3rd function kit on another tractor at my local dealer and didn't like it. The handle was bulky, uncomfortable and it had a toggle switch vs easy to,use buttons.
Great feedback! Thank you! Did dealer install your 3rd function kit for you?
   / Installing Land Pride 3rd Function on L3301 with backhoe #6
Just curious because I am new here. Am I correct in understanding the third function kit is to allow another set of hydraulic controls, such as a root grapple? If this is correct then what are some other uses or attachments? I need to get my Christmas wish list started soon...LOL
Hello! Great question. Yes the third function on a loader is primarily for adding a open close circuit on a loader.
The circuit could be used to control a grapple, snow plow (angle), 4 in 1 bucket, etc.
The system uses an electric switch to shift a hydraulic solenoid valve. So uses another switch you could also uses the same valve with a different set of hoses to control a rear implement like a thumb on a backhoe.
I'm still puzzled why tractor OEMs don't offer these valves as factory options. I know Kubota is finally offering on some of their tractors.
   / Installing Land Pride 3rd Function on L3301 with backhoe #8
So here's some pics of my hydraulic circuit. Power beyond goes straight out to the backhoe and loops back under the right side floor pan and then connects to the third function valve. From the third function valve, flow comes It and goes directly into the loader valve. Pretty straight forward as long as you have the correct hoses.
View attachment 522453View attachment 522454View attachment 522455
I greatly appreciate those pics!! Thank you very much! Really helps me to understand what is going on.
Thank you for taking the time to do this for me! (0:
   / Installing Land Pride 3rd Function on L3301 with backhoe #10
They don't have to be electric, they can be a manual lever too. Diverters are called 3rd functions frequently too. A diverter is just a 2 way valve that will divert your existing lift or curl circuit to a 3rd function. Generally electrically actuated, but could in thoery be manual too.
You can hook up anything to a 3rd function to some degree. I hook my hydraulic SSQA post hole digger to mine & run the power angle on my SSQA snow plow.
A true 3rd function was an OEM option on my L4060 Grand Kubota. Not sure if it's an option on the economy Kubotas. Generic aftermarket diverter kits are easy to install. True 3rd function kits aren't that hard to install either.
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
TRUCKING INFO (A50775)
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
FORREST RIVER CHEROKEE CAMPER (A50854)
FORREST RIVER...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
2007 TRANSCRAFT 40X96 FLATBED (A50854)
2007 TRANSCRAFT...
