Cottage Carport
/ Cottage Carport #123
“ Old and tired” describes most of us.
/ Cottage Carport #127
Will the bottom of the steel roof be insulated?
/ Cottage Carport
No insulation.
/ Cottage Carport
No, no intentions of walls. Primary purpose of carport is water catchment. Secondarily, Canada Dave gets to park his car there.
Of course, should things change and we were to end up living in cottage again...
/ Cottage Carport
A very good day. Cottage side of roof installed, ridge cap installed, flow diverter on edge by gutter.
Not a very good pic, need a drone view
Someone asked about the Versatube kit. I’d rate it a solid 9 of 10. I would have preferred another 2 or 3 rows of purlins per side. I’ll also likely add some diagonal bracing to sides. I would have preferred 4ft vs 5ft spacing between trusses.
/ Cottage Carport #134
Yep, now I see the intent.
Is your catch water the only source at the cottage?
/ Cottage Carport
Yes, we are completely off grid, no utilities other than cellular and satellite.
/ Cottage Carport
So as to what’s ahead on carport.
Some trim for sure and still a bunch more screws. Will be adding some additional bracing, but first...
Two additional areas for roofing.
Approx 15x6 over the rear deck and approx 8x6 to tie in from existing deck cover
Then I will rework the gutters and catchment plumbing. Significant capacity increase
No plans to add another tank to the current 3kgal. We average 140 inches rain/yr. that would be nearly 40 tanks/yr.
/ Cottage Carport #137
Sodamo is your math flawed? sq ft divided by .6 equals gallon, correct?
/ Cottage Carport
No progress today. Energy conservation and body recovery.
2011 WESTERNSTAR 4900SA (A63569)
2011 WESTERNSTAR...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
Year: 2011 Make: Isuzu Model: NRR Vehicle Type: Truck Mileage: 221,488 Plate: Body Type: Tiltmaster (A61573)
Year: 2011 Make...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
