JD 4600 - Grinding Starter Issue
/ JD 4600 - Grinding Starter Issue #1
quid_non
Member
My 4600 has had an issue off/on with a loud "grinding" sound sometimes when I turn the key on. After one or two attempts the started will engage and turn the flywheel over and start. The problem is getting worse. Anyone else have a similar issue? Is it likely a damaged "bendix" type gear on the starter or a bad spot on the flywheel? Any suggestions to check?
Thanks
/ JD 4600 - Grinding Starter Issue #2
/ JD 4600 - Grinding Starter Issue #3
it sure sounds like a bad starter, you can buy a new one, or have your old one repaired at an electric motor repair shop..
/ JD 4600 - Grinding Starter Issue #4
I found I could not get a new Bendix spring for my aging Mitsubishi. A whole new starter from a local starter shop was only somewhat more expensive than the Bendix assembly alone. I replaced my starter and I've not had the grinding since. The starters can be kind of generic. If you have a local starter shop take the starter there first.
/ JD 4600 - Grinding Starter Issue #6
Don't keep grinding the starter you will ruin the flywheel .....
/ JD 4600 - Grinding Starter Issue #7
At a minimum, I'd remove the starter and look at it to see what may be happening.. before grinding any more.
Parts showing what looks like a gear reducer, after the armature (key #7), then grouping #21 called the "switch" , and grouping # 26 called the "clutch". May be helpful when looking at the starter once removed. Wish you well.
/ JD 4600 - Grinding Starter Issue #8
Thanks
I'm having a similar problem the past month with my JD4300. Assumed it was the 5 year old battery so replaced it. With new freshly charged battery it started normally so I assumed problem was solved. The tractor sat unused for a week then the grinding sound reoccurred. :pullinghair: Then I thought maybe the new battery was defective, couldn't hold a charge more than a week. Thank you for starting this thread and to those who replied. Based on this thread, there's probably more going on than a battery problem. :confused3: Strange thing is the grinding only happens when the engine is cold. Tractor starts normally when engine is hot. :confused2:
/ JD 4600 - Grinding Starter Issue #9
Now with the 4300 entering the thread, has my interest even more. :)
"grinding" sound.. is the engine turning over at the same time you are hearing "grinding" ??
And this sound is not a chatter, or a clicking sound? (what I would associate with a low battery)
/ JD 4600 - Grinding Starter Issue #10
My 20 year old 4600 suffered from same issue - I replaced the starter and have had no problems since.
-Bob
Iranch IRET13 Electric Tricycle (A60463)
Iranch IRET13...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
(INOP) 2009 FORD CROWN VICTORIA (A59823)
(INOP) 2009 FORD...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
