JD 4600 - Grinding Starter Issue
   / JD 4600 - Grinding Starter Issue #1
quid_non
My 4600 has had an issue off/on with a loud "grinding" sound sometimes when I turn the key on. After one or two attempts the started will engage and turn the flywheel over and start. The problem is getting worse. Anyone else have a similar issue? Is it likely a damaged "bendix" type gear on the starter or a bad spot on the flywheel? Any suggestions to check?
Thanks
   / JD 4600 - Grinding Starter Issue #2
   / JD 4600 - Grinding Starter Issue #3
it sure sounds like a bad starter, you can buy a new one, or have your old one repaired at an electric motor repair shop..
   / JD 4600 - Grinding Starter Issue #4
I found I could not get a new Bendix spring for my aging Mitsubishi. A whole new starter from a local starter shop was only somewhat more expensive than the Bendix assembly alone. I replaced my starter and I've not had the grinding since. The starters can be kind of generic. If you have a local starter shop take the starter there first.
   / JD 4600 - Grinding Starter Issue #6
Don't keep grinding the starter you will ruin the flywheel .....
   / JD 4600 - Grinding Starter Issue #7
At a minimum, I'd remove the starter and look at it to see what may be happening.. before grinding any more.
Parts showing what looks like a gear reducer, after the armature (key #7), then grouping #21 called the "switch" , and grouping # 26 called the "clutch". May be helpful when looking at the starter once removed. Wish you well.
   / JD 4600 - Grinding Starter Issue #8
Thanks
I'm having a similar problem the past month with my JD4300. Assumed it was the 5 year old battery so replaced it. With new freshly charged battery it started normally so I assumed problem was solved. The tractor sat unused for a week then the grinding sound reoccurred. :pullinghair: Then I thought maybe the new battery was defective, couldn't hold a charge more than a week. Thank you for starting this thread and to those who replied. Based on this thread, there's probably more going on than a battery problem. :confused3: Strange thing is the grinding only happens when the engine is cold. Tractor starts normally when engine is hot. :confused2:
   / JD 4600 - Grinding Starter Issue #9
Now with the 4300 entering the thread, has my interest even more. :)
"grinding" sound.. is the engine turning over at the same time you are hearing "grinding" ??
And this sound is not a chatter, or a clicking sound? (what I would associate with a low battery)
   / JD 4600 - Grinding Starter Issue #10
My 20 year old 4600 suffered from same issue - I replaced the starter and have had no problems since.
-Bob
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Galvanized steel Fence (A53424)
Galvanized steel...
2016 BOMAG BW 177D5 SMOOTH DRUM ROLLER (A52707)
2016 BOMAG BW...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
EINGP PHT620 HAND PUSH ELECTRIC FORKLIFT (A57192)
EINGP PHT620 HAND...
