TMGT's shop build
/ TMGT's shop build #81
No forklift but always on the lookout for one, until then I might build a swinging i-beam crain.
This 16' crank up is what I use:
/ TMGT's shop build
I have been on the lookout for a fume extractor. Those aren't cheap! At least for name brand ones.
No they aren't! However this one was, which is the only reason I have it.
/ TMGT's shop build
I've been looking for one of those but they always seem to go for more then I want to pay. When I worked with a guy installing auto lifts we use to use some of the old style with the removable mast and hand winch on the back. I was always amazed at how much those things could lift.
I have extra I beams laying around so will probably still make a crane, unless I find a forklift first.
/ TMGT's shop build
It's been a while since I've worked on the shop, mostly been trying to get the siding on the house done. I'm not as far along with that as I'd like to be but I did have to replace all the facia board which was quite a job, also had new gutters installed on the house and shop which is something I've been wanting to for a long time.
Since it's too cold and rainy to work on siding right now I decided to take a break and make the storage area for one of the larger 20hp screw compressor that I picked up over the summer.870329441.jpeg
Unfortunately the compressor I'm keeping is the larger of the 2 and too tall to fit on the current mezzanine by a couple inches, I thought about separating the compressor from the tank but it would have taken up even more space so decided to give the compressor it's own home.
Made a 4x8 section just for it to sit on, the smaller reciprocating compressor I have will be a backup and be mounted on the mezzanine next to it and be plumbed together giving me 200gal of storage capacity.20191217_172400.jpeg
I hope to have it mounted and wired before Christmas, unless the weather warms back up so I can work on the house siding some more.
Luckily for me I also managed to pick up a forklift over the summer, which makes moving stuff so much easier!20190718_195129.jpeg
/ TMGT's shop build #86
The forklift will make life SO much easier. I hope you have 44-48 inch forks also? If not you will need to pick up a pair.
The compressor is going to look good in the dedicated spot.
House is looking good
/ TMGT's shop build
Sure do, have a couple sets of 46in forks laying around here, I keep thinking I'll change them out but the 6ft ones are just too handy, and they weigh a LOT!
The forklift already made getting my finger brake inside much more enjoyable, the skid steer was struggling a bit with it the brake is now on wheels.
It also put the other compressor for my buddies shop up on the mezzanine to store it. 20190803_185630.jpeg
/ TMGT's shop build
Compressor is in place and wired, man this thing is quiet! Now I just need to start on the plumbing.20191219_182821.jpeg
/ TMGT's shop build #89
Looking good :thumbsup:
/ TMGT's shop build #90
It looks right at home!
/ TMGT's shop build
Haven't been making much progress on the shop, had to make some repairs after a dead tree fell and hit it in a wonder storm a few weeks ago. 1154657605.jpeg
I already repaired the roof but am waiting for warmer weather to fix the siding as it's too brittle in the cold to unzipper. I probably will just straighten the gutter, luckily it's on the side that is kinda hidden.
On a positive note, I have finally starting installing my lift, if all goes well it should be up and running by the end of next week.20200207_182431.jpeg
/ TMGT's shop build #93
That's disappointment. Looks like it's been dead for quite awhile, if that's what is laying on the ground there.
/ TMGT's shop build
Unlucky parked tractor also?
Actually zero damage to that mower believe it or not. The limb sitting next to it hit the roof, broke and came straight down, hit the siding and stuck un thr ground. Luckily it didn't even tear the tyvek under the siding.
/ TMGT's shop build
It probably was, it broke off about 20ft off the ground and the wind appears to have blown it against the natural lean.
In the past couple years I've had a lot of trees die off. I currently have 3 large red oaks and 2 large white oaks that I need to take down.
2 years ago I lost probably about 8-12 trees that blew over in a wind storm, nothing worse then a week+ of rain then a wind storm.
This one would have cut through my house if it had gone the other way.218911592.jpeg
/ TMGT's shop build #96
Your trees really don't like you!!! :)
In town, they fall over all the time because they where planted after the houses where built and watered with the grass for 50 years without every building up a real root system to hold them in place. Then after a week or steady rain, the ground gets saturated and they just fall over from their own weight. I watched one do this on a beautiful clear day. It just slowly fell over across the street from where I was working.
Could your's be dying because of damage from construction?
/ TMGT's shop build
Doubt it, all the trees that are dying aren't anywhere near the construction area. The last 2 white oaks were a surprise, the one I didn't know was dead until I came home from being gone for a week and my trailer was covered and branches with a hole in the deck. 607589632.jpegI've lived here 8 years and the past couple have been bad about dead trees.
You can see the relation of that big double white oak to the house.
/ TMGT's shop build #98
It's been my experiences with timber that it takes 15-20 years to truly understand the cycle of dead trees. Three years ago was the worst year I've had in the last 20 in regards to Oak trees. With three wood stoves feeding out of the wood pile we are just now sort of getting caught up.
Then we may go into a cycle where we are having to cut healthy trees in areas that need thinned to get enough firewood.
Have no idea what causes this other than natural cycles?
/ TMGT's shop build #99
As I understand it, there is currently an oak blight that damages roots going around.
Here in the northeast, there was a 3 year cycle of gypsy moths following a year or two of drought that knocked out roughly a quarter of them.
/ TMGT's shop build #100
We had 2 days or rain with my 6 inch rain gauge overflowing. Some people are reporting over 7 inches of rain.
When I closed the chicken coops last night, I heard an odd sound, so I stopped and listened closely, and realized it was a tree falling over. I'll go look for it this weekend when it's less muddy out.
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2017 Hyundai Trailer (A62613)
2017 Hyundai...
CASE 850M WT CRAWLER DOZER (A64277)
CASE 850M WT...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
