No drill fasteners for stringing wire/cable bundles
/ No drill fasteners for stringing wire/cable bundles #1
Silvic
Gold Member
West of no-where
I tried the search function and struck out.
Several years ago maybe more like 7-8 years ago there was a thread on no-drill wire and cable attachment fasteners.
The kind that hold wire or split-loom as it is strung along on the frame of a trailer or truck.
Most of the time you put a small screw in and bolt the holder to the metal frame.
Someone posted about a new (at that time) device that was put on with a VERY STRONG adhesive and was permanent without drilling holes.
Can't really find the thread and have not found anything that seems to be that strong in any of the stores.
Does anyone have any suggestions?
Thanks
/ No drill fasteners for stringing wire/cable bundles #4
Frame rail clips - quick & secure.
/ No drill fasteners for stringing wire/cable bundles #5
The adhesive can't be any stronger than what it is attached to. Under a trailer, if that is Enamel or worse, Powder coat, good luck with that. So, one would be best to grind down to bare metal and if you hve to do that, drilling would be easier, or better yet, self drilling Stainless screws.
I believe your thinking of "click bond":
That is exactly what I was thinking of. Have you used them and what was your opinion of them in service?
/ No drill fasteners for stringing wire/cable bundles #7
I have not, just remembered the many discussions on it.
/ No drill fasteners for stringing wire/cable bundles #8
They work great. Dragon eggs, on here has used them for several things and has had good luck with them.
/ No drill fasteners for stringing wire/cable bundles #11
I welded bolts onto the cross members and frame of my trailer. Also put one at each light for a ground. I used stainless 1/4-20x3/4in bolts.
/ No drill fasteners for stringing wire/cable bundles #12
Re Click Bond
Here’s a sample I did with swivel a cable tie holder on mild steel.
Painted metal ground to bare metal.
A vise was the handiest object I had.
The adhesive will hold for a much heavier weight but I’m certain the cable tie would stretch and fail first.
Totally unscientific but I guess you get the idea.
HTH.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2018 Club Car Carryall 1700 4x4 Utility Cart (A61572)
2018 Club Car...
(8) BAR JOIST W/ ENGINEERING TAGS ATTACHED (A63291)
(8) BAR JOIST W/...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
2022 EZ-GO ELITE...
