Backhoe Cracked Transmission case between bolts attaching backhoe
/ Cracked Transmission case between bolts attaching backhoe #41
Run a video camera as you use the backhoe. Also, maybe time to get the welder out and add to the subframe so that the backhoe is better supported.
I'd like to see the OP in action. 75% of me thinks it would be okay. 25% of me wonders if he beats the $h*t out of it. I repeat, stumps are evil.
/ Cracked Transmission case between bolts attaching backhoe #42
It's about the worst thing a homeowner can do to a CUT with a backhoe. That and dealing with rocks.
I built my backhoe to take a beating and every once in a while, something still gives. So I can imagine how much more sensitive a tractor can be with a backhoe since it's not really designed for it.
/ Cracked Transmission case between bolts attaching backhoe #43
You mean to tell me you’re not supposed to pull and pull on a stump so hard you repeatably lift the front tires and loader bucket off the ground??
Maybe he should sell and buy a John Deere ! Oh wait a minute they have casting issues too.
/ Cracked Transmission case between bolts attaching backhoe #44
I remember when the OP had his first occurence of the cracked transmission case from his backhoe use, and all the problems he experienced getting Kioti Warranty to work with him. We all wished him good succes at repairs. However, I am surprised to find the cracked case has occured again.
Either were looking at a serious design flaw, or the OP has abused his tractor during backhoe usage. Tractors are basically AG equipment, and not designed for trenching in rocky hard terrain. Digging stumps out with a backhoe is abuse in my opinion. I can grind any stump 6 inches below ground in 15 minutes with the Kioti stump grinder. I can grind 50 stumps in a week, and never need my backhoe for this task.
Also, are we looking at two cracked cases of the 10,000 Kioti tractors sold??
/ Cracked Transmission case between bolts attaching backhoe #46
SR...read my post very carefully, i ASKED are we looking at two occurence of cracked transmission cases. You tell me how many Kioti tractors have cracked transmission cases.
I also am aware of an occurence where bolts for the subframe stripped out the threads.
/ Cracked Transmission case between bolts attaching backhoe #47
No clue, that's why I have no clue how many cracked... And, that's why I asked the question...
SR
/ Cracked Transmission case between bolts attaching backhoe #48
That said, I don't see many threads about this (Kioti) problem on TBN.
/ Cracked Transmission case between bolts attaching backhoe #50
There seems to be some questioning of whether backhoe abuse is the source of the trans case failures. In my instance, my dealer's head tech happened to be on sight 1 hour prior to the failure working on my NX for a DPF issue. He seen what I was digging and how I was digging it. In this case I was digging 300' of water line 6' deep in compacted pit-run with a 12 inch wide bucket and the direction of dig was with the long axis of the machine, not angled. He specifically said, that is what the backhoe is built for and that's how you dig in this circumstance. Later, when the dealer came to retrieve my broke tractor they took pictures for the warranty claim which included position of the tractor to the work being performed, placement of the tires, and location of the outriggers. Both the dealer and the warranty officer received those pictures and concluded that user error was not reason for the failure. Warranty covered full cost of the repairs.
/ Cracked Transmission case between bolts attaching backhoe #51
As a new owner, I believe I have been cautious and conservative in operating the tractor. That said, as a new owner, I may not know what "normal" operating parameters are and that what I am doing shouldn't be done and could lead to the problems I am experiencing. Please allow me to explain and seek your thoughts. My use has entailed digging up stumps, many ditches, some retaining wall work, and leveling a place for a garage. North Idaho is replete with rock outcroppings so I have chipped away at some rock though I have been careful not to drop the bucket to turn it into a hammer. A lot of my backhoe work has been at an angle to the long axis of the tractor and, in some tight places, I have done some trenching at nearly 90 degrees to the long axis. Would working at an angle to the long axis tend to torque the backhoe and hence the mounting brackets that the mounting rails slide into? Are the stabilizer arms designed to prevent this torquing? Should I be careful to dig only within a ten or twenty degree range of the long axis of the tractor and use the additional pivot range only for dumping the bucket? I haven't been able to find any limit to the range of operation in the manual. Is there such a limit ... explicit or implicit?
Hey MossRoad, thanks for the welcome and the caution. Please jump on me if I seem to be straying. As you point out, ignorance sure won't be bliss.
Again, thanks to you all for taking your time to help me.
There may be some clues here. Stumps are evil
/ Cracked Transmission case between bolts attaching backhoe #52
Probably for the same reason you put lame music on your video's......:laughing:
Got it: you don't listen to music on the radio and you're a riot at parties.
/ Cracked Transmission case between bolts attaching backhoe #53
A properly mounted backhoe should not crack the transmission. Moreover, even assuming the operator is beating the snot out of the hoe, then I expect the pins to take that beating if the subframe is properly distributing the load and not crack the transmission. This sounds like a design error that should be rectified.
/ Cracked Transmission case between bolts attaching backhoe #54
I generally agree with whatever MinnesotaEric has to say. I have to admit however, that I am a little queasy thinking it would be okay to beat the snot out of a backhoe and not worry that you might damage your CUT.
/ Cracked Transmission case between bolts attaching backhoe #55
I sure hope were not looking at a Kioti design flaw for the Backhoe mount. I have spent well over an hour running searches on Kioti backhoe and cracked transmission cases, and almost all search results reference this very thread. I did find in 2014, a discussion on issues with cracks in the forward subframe, associated with welds. But nothing much on cracks in transmission cases.
I have the CK4010 tractor with backhoe and am concerned about systemic problems with the backhoe mounting.
/ Cracked Transmission case between bolts attaching backhoe #56
I’m also with Eric. A properly designed machine should not break at mounting points. Pins are wear items and from my experience are expected to fail / wear with time and use.
Hydraulic bypass valves are designed to limit power and damage.
If using outriggers and proper hydraulic pressure you should not in theory have problems.
The exception I can think of is driving around carrying something with the hoe. Then all bets are off.
I’ve dug at stumps for days and never had a problem other than worn pins.
No question there’s a night and day difference between digging stumps with a SCUT vs the smallest of excavators. Very different purpose built machines but with that said a SCUT with a factory hoe should be able to dig for days without issues. No different than doing loader work or implement work all day.
Joel
/ Cracked Transmission case between bolts attaching backhoe #59
My guess is that excessive down pressure on the sub frame was the probable cause. (failure to engage the stabilizers)
I think that Kioti is amazing for covering this damage under warranty!
We've put about 700 hours on our KB2385 backhoe to dig up hundreds of stumps and rocks. Some tree stumps were almost 2 feet in diameter, and some rocks were over 2 ton.
We cracked the sub frame and had to get it welded. We cracked the main backhoe frame, and had to get it welded. We even broke the main boom cylinder twice and had to get it welded. We never had any issue with the tractor.
/ Cracked Transmission case between bolts attaching backhoe #60
With that sort of history, it would seem quite obvious that you are using your machine for work outside it's design parameters (abusing!).
2015 WESTERN STAR  4700 SF DAY CAB (A60736)
2015 WESTERN STAR...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
2016 Lincoln MKC SUV (A61569)
2016 Lincoln MKC...
2009 TIGER MANUFACTURING VACUUM TANK TRAILER (A60736)
2009 TIGER...
