As a new owner, I believe I have been cautious and conservative in operating the tractor. That said, as a new owner, I may not know what "normal" operating parameters are and that what I am doing shouldn't be done and could lead to the problems I am experiencing. Please allow me to explain and seek your thoughts. My use has entailed digging up stumps, many ditches, some retaining wall work, and leveling a place for a garage. North Idaho is replete with rock outcroppings so I have chipped away at some rock though I have been careful not to drop the bucket to turn it into a hammer. A lot of my backhoe work has been at an angle to the long axis of the tractor and, in some tight places, I have done some trenching at nearly 90 degrees to the long axis. Would working at an angle to the long axis tend to torque the backhoe and hence the mounting brackets that the mounting rails slide into? Are the stabilizer arms designed to prevent this torquing? Should I be careful to dig only within a ten or twenty degree range of the long axis of the tractor and use the additional pivot range only for dumping the bucket? I haven't been able to find any limit to the range of operation in the manual. Is there such a limit ... explicit or implicit?
Hey MossRoad, thanks for the welcome and the caution. Please jump on me if I seem to be straying. As you point out, ignorance sure won't be bliss.
Again, thanks to you all for taking your time to help me.
