BH stabilizer claws
/ BH stabilizer claws #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
After using the BH with the factory flat plates, I soon realized I had to put on some claws to prevent the BH from just pulling the tractor around. It was so simple and easy, I cannot believe I did not do it sooner and would just keep repositioning the tractor! Took about an hour to cut, drill, and mount. They made a tremendous difference when digging.
/ BH stabilizer claws #2
You'd think for as much as you paid for that backhoe it would at least come with some decent stabilizer feet . Some times the best fixes don't take much time or effort just a little thought. You get a Hey Atta Boy.:thumbsup::drink:
/ BH stabilizer claws #3
^^ They're made so people can adapt to their own environment. Some use a rubber type cleat, others find they don't need anything. I used angle iron on mine bent 90 degrees so that they'd grip in two directions.
593651d1551224389-what-did-you-do-your-or_angle-jpg
/ BH stabilizer claws #4
I've seen wheels with tires attached to the stabelizers. The backhoe was working on pavement.
/ BH stabilizer claws #5
I like the B21 pads. One side is steel ridges when you want to dig in. The other side is rubber pads for surfaces you don't want to mess up.
/ BH stabilizer claws #6
I did the same to my B26 but I welded the plate to mine. Then I found that just adding to the two sides as you have done just helped keep it from going backward and did nothing for it slipping to the side if I was digging off center. Next I just completely boxed it in on all four sides. I was afraid that it was going to hold/pack with mud but that isn't happening. I just added 1.5" tall plate to all sides. That seems to be enough to hold it steady in most instances.
/ BH stabilizer claws #7
My 757 BH on my TC30 had the same issue . Could buy either the pavement pads or dirt pads at $$$$ . So made my own .
If I do need to go on pavement or another surface that I don't want to tear up , ( Lawn ) , I can just unbolt , since the base is just bolted on , while the tangs are welded to base .
Fred H.
/ BH stabilizer claws #8
The Kubota flip over stabilizer pads are the easiest to use.
Steel grip on one side, flip over ...rubber on the other side.
My TLB is missing the rubber pads.
I am looking for an inexpensive rubber source, to make my own.
/ BH stabilizer claws #9
Mine are shaped like the OP's, but made from a large piece of C channel. I tried boxed in on all four sides. They were instantly packed full of material and slid like flat plate.
I've saw the X design on some large hoes from the factory.
/ BH stabilizer claws #10
I took the rubber pads off my machine because I didn’t like them. I was thinking about making about a 6” extension for my m59 pads. The stabilizers don’t lift high enough for my liking.
/ BH stabilizer claws #11
Mine look like cut up old tire side walls , Factory from kubota
/ BH stabilizer claws #12
Yeah, both my B21 and B20 hoes have feet like that.
My Woods clone hoe (Prairie Dog) has cast steel feet with a rubber shoe on one side, and a pointed side that digs in.
I wonder why hoe makers have gotten away from flip-over feet....
/ BH stabilizer claws #13
Loading dock bumpers are the same thing. Laminated rubber. Not inexpensive. Taking a hacksaw to an old tire would probably work too.
/ BH stabilizer claws #14
The loading dock bumpers are pretty expensive. Want about a cheap tire chock mounted pointed side down? IMG_8271.JPG
/ BH stabilizer claws #15
i used tire tread off an 18 wheeler i found an the side of the road. cut them with a bandsaw to size, drilled holes and stacked them and bolted them together. really tough!
/ BH stabilizer claws #16
Truck flaps? I got a couple and cut them up when I needed to replace the debris baffles on my brush mower.
That's why I did the L pattern.
/ BH stabilizer claws #17
Didn’t like the rubber pads for the M59? I was thinking of getting some factory pads or homemade for my M59.
Have rubber pads on the B26 and work real well. Think the same pads fit all their TLBs. I do like the couple of inches of added height they add.
/ BH stabilizer claws #18
No, the Kubota pads already have a lip on both sides like some of the modified pads here and the rubber didn’t let them bite. I don’t use the backhoe on concrete or asphalt much either. For the time I do just the metal pads don’t really hurt anything as long as you don’t slide them around.
/ BH stabilizer claws #19
My Woods 750 had good steel pads but not so good on the asphalt. I made two types, one out of treated wood and the other out of M60 tank pads, seconds from Goodyear when I worked there. They worked well also.
/ BH stabilizer claws #20
I haven’t got many hours on the M59 yet but see the need for improvements with it’s powerful hoe. The 4500 Ford BH it replaced had nice “X” pads and the stabilizers would pick the machine up higher. The extra extension is helpful on our hillside farm and soft ground to level the machine. So your thoughts on 6” spacers makes sense. Think I might make them wider too.
2019 International LT625 Sleeper 48" (A62613)
2019 International...
Caterpillar 259D (A62180)
Caterpillar 259D...
UNUSED WOLVERINE QMP3-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
1994 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61567)
1994 Gehl DL11-55...
