Why huge differentials on trucks?
/ Why huge differentials on trucks? #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
Why do pickup trucks have such huge differentials?
The ones on Subarus are small. The one on our Miata is small, and its final drive ratio is 4.1. Same for our 1983 240D Benz. It was basically the same drive with independent rear axles as the Miata and Subaru have.
Why are pickup trucks (and the big truck's) differentials so large?
Ralph
/ Why huge differentials on trucks? #2
A larger diameter ring gear requires less torque input to rotate than an smaller diameter gear.
/ Why huge differentials on trucks? #3
Ralph my first guess (in a heavy vehicle) would be the horsepower and torque sent through it along with the tens of thousands of pounds resisting these forces are not present in a light car where the " circuit breaker " is the tire simply breaking traction.
Then there's the less stress with a mechanical (think leverage) advantage.
/ Why huge differentials on trucks? #4
I will guarantee that differentials are engineered to be no larger than they need to be to perform in the worst case scenario the truck is likely to be called to perform. The bean counters will make sure the engineers don't run wild. As pointed out by others trucks often have to move large loads, have "taller" tires and sometimes have dual wheels or even tandem axles. All of this equates to more torque needed to be applied to the propeller shaft. The differential must be able to "hang together" under these circumstances. The Engineers make certain that it will. The bean counters make certain it "just" does that and no more. This applies to every other component of the drive train as well. Enough, and that's all. So to sum up, truck differential are not huge.
/ Why huge differentials on trucks? #5
How do tire diameters and tow ratings compare between the Miata, the Benz, and our HD or Super Duty pickups, even half ton models?
Like James says, everything proportional and darned little is 'overbuilt' these days ..
/ Why huge differentials on trucks? #6
The contact patch between the teeth of the ring gear and pinion increases with the diameter of the pinion and the depth of the gears. Gear oil has its limits on keeping those gear teeth apart so they don't wear down from friction. The weight of the vehicle, tow rating, engine torque, all dictate how large the differential gear contact patch must be so the oil can succeed. If the gears are bigger, the case is bigger too. With a larger load bearing on the gears, there also must be bigger bearings to support the load. All of this makes heat so a large case to hold more cooling oil is needed too. Hypoid gears (off center pinion) means the gears do a bunch of rubbing as they rotate. This is why the anti-friction additives are so important. Hypoids are smooth and quiet, and that is why they use them.
/ Why huge differentials on trucks? #7
So why don't they over-build the diffs on all vehicles? Because big diffs cost MPG, especially in cold weather. Big gears and big bearings swimming in thick oil takes some HP to turn. So they come out with better lubes which allows them to go a bit smaller on the diff design. If you try towing 25k up a mountain with 900 ftlbs of diesel torque, all through a Miata diff, the gears will be toast. Why? The oil can't keep 2 tiny gears apart and it will self destruct.
/ Why huge differentials on trucks? #8
On trucks and larger equipment you usually have this solution, and then you can reduce the size of the differential.
/ Why huge differentials on trucks? #9
I dug around in my shop and could only come up with two ring/pinion sets. Sorry. This would have been a great thread to display 3 or 4 different sizes.
First is from a Dana 44 differential. It's a common size in 1/2T equipment and actually some autos. This set is 4.56 ratio. The larger the number, the slower the gear ratio. The larger the number, the smaller (less teeth) the pinion gear has and more teeth the ring gear has.
This set failed. They came out of one of my offroad buggies. I'll let you guys see if you can spot the failure.
I laid the T square in the pic to give an idea of size.
Second is a Dana 30 set. It's commonly found in the front axle of Jeeps and other compact trucks. This set is 3.55 ratio. Notice larger pinion count compared to ring count.
This set was replaced to get a lower ratio, slower vehicle speed, more pulling power.
Here's a comparable pic with both sets. Notice how much larger the 44 is over the 30.
My Son's run Dana 60 axles. Their ring/pinions sets are gigantic compared to these sets. Dana 60 size is what's common in 3/4T or 1T trucks.
Over the road trucks have ring/pinion sets that would make these look tiny.
Hope this helps explain the differences in strength that larger axles have. Wish I had gears from one of the vehicles you listed to show how tiny they are. :)
/ Why huge differentials on trucks? #10
I see some "pieces parts" (teeth) chipped on the ring gear of that Dana 44 :)
/ Why huge differentials on trucks? #11
ruffdog mentioned larger axles requiring larger cases to hold more oil. Actually the case size is to be strong enough to not distort under load. Secondary benefit of holding more oil.
A properly set up differential, properly maintained, not abused, can potentially run hundreds of thousands of miles without failure. Most common failures are bearings which allow distortion which in response destroys the gears.
Setting up a differential from a pile of parts laying on a bench is very technical. Very Technical.
/ Why huge differentials on trucks? #12
Good catch James!!!
I'm guessing shock failure from the abuse our buggies withstand. Came out of my front differential. I noticed under slow hard load I would hear a "thunk" at times. I finished wheeling that day and then tore it apart. A tooth had failed on the ring gear. I'm guessing the adjacent teeth could no longer carry the load and started failing. The single chipped tooth on the opposite side was probably caused by a piece of tooth pickup by the oil.
/ Why huge differentials on trucks? #13
And when they are not set up right, and the teeth don't mesh in the right spot, they whine. We had a Explorer from that bunch of Ford Explorers that came thru the line and the setup of the differentials for about a week was not done right. Known problem, but they made it out to the public. And we had one.
/ Why huge differentials on trucks? #14
Good catch James!!!
I had a lawn mower the chipped a tooth and that piece got caught between the ring gear and the case at a low spot without enough clearance and it pushed out of the aluminum case. Big trail of oil on the ground as the wife drove it to the barn. Not pretty..
/ Why huge differentials on trucks? #15
If you think pickup differentials are huge go look at medium and heavy duty trucks. As for the size look how much more weight and toque the trucks have over a Subaru.
/ Why huge differentials on trucks? #16
In my modified world here's an example of tire diameter differences. The more stress applied to the differential, the bigger and stronger the differential needs to be.
The larger buggy is on 48" tires and Dana 60 axles. The smaller is on 33" tires and Dana 30 front, Dana 44 rear.
/ Why huge differentials on trucks? #17
Saw a friend's Blazer do that one day. He got in to back out of the shop and it wouldn't move. He mashed on the gas and puked the tooth out the bottom of the case..... :eek:
/ Why huge differentials on trucks? #18
My street Jeep whines. I added an electronic locker to the rear. Tore it apart four times to reshim. Gave up and live with it. I'm the only one that hears the whine when you let off the throttle. Everyone thinks I'm being picky. Maybe so, but it didn't do that before I swapped the carrier. :eek:
/ Why huge differentials on trucks? #19
Yep. It's a handful to pick up a ring gear from a heavy truck diff.
And they have the torque to explode the driveline if trying to move an immovable load in low gear.
/ Why huge differentials on trucks? #20
I bet he said a word or two that you can't print!..
2016 CATERPILLAR 305E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
PALLET OF MEC 8000 PUMP AND V8 ENGINE BLOCK (A67714)
PALLET OF MEC 8000...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
2011 FORD CROWN VICTORIA (A66091)
2011 FORD CROWN...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
