Jd4310 ehydro
/ Jd4310 ehydro #21
hmm, something to check out. Thats why I love this place,
Are those hoses on a check valve or is there a valve you need to close to reroute them?
If you compare the 2 pictures, mine has a gold pin and hairpin clip on the loader frame just below the cylinder. That holds a plastic clip (on the inside of the frame) for a large heavy duty zip tie to hold the lines tight against the frame. Your picture shows the empty hole in the frame. Cheap fix, but you can reroute the hoses and het the clip and pin. You need the clip to keep the hoses pulled tight and secured.
/ Jd4310 ehydro
AHH that explains it. Thanks!
They connect with a quick disconnect but it looks like they are just tied on the wrong side of the upright. I imagine you can just cut the tie and reroute them without having to do anything else.
Thanks, I am researching the 300X now. from what I see, probably not a deal killer. I will just be using it from gravel from time to time, and dirt hauling to get my property in shape. then mostly use it to haul logs I cut. Also gonna use it to keep parts of my property trails clean and bush hogged.
It comes with a LX 5 bush Hog
72 inch belly mower
655 tiller
forks
imatch? (not sure what this is)
and ballast box
/ Jd4310 ehydro #23
Loader info.
  • 300X.pdf
/ Jd4310 ehydro
thanks for the info!
/ Jd4310 ehydro #26
Good luck. They are nice tractors.
/ Jd4310 ehydro #29
is the LX5 a good 5 foot rotary cutter/bush hog?
No idea on that one. Might want to start a new post in attachments. But in general for cutters, you want to make sure it has a slip clutch and it is serviced. Plenty on the forum about that.
/ Jd4310 ehydro
Welll had appointment for 5 days, when I get their he thinks I am someone else. Even though I was ready to offer, he said they guy he thought I was was coming with money, and he was sorry.
Gotta love it.
/ Jd4310 ehydro #31
Maybe something better will come along.
