Jd4310 ehydro
/ Jd4310 ehydro #1
Bryan1965
Hilliard, ohio
2016 Kubota L3901
Going to look at one in two days, wants 15200 for this and a lot of attachments. Anything I should look for when inspecting tractor?
/ Jd4310 ehydro #2
Just make sure everything works and looks good. Here is the online operators manual if you want to read up on it before going to look. OMLVU13193_H2
Does it have the 430 Loader or 420?
They are fairly light tractors. You have to use a weight on the back to load the loader or it will pick the rear tires off the ground.
/ Jd4310 ehydro
Thank you, the manual is great I will study it, the only number I see on loader is 500X?
/ Jd4310 ehydro #4
Possibly 300x?
That was available for a short time just before they discontinued the 4x10 series.
They where good solid machines.
/ Jd4310 ehydro
Here, this is the number on the loader..
/ Jd4310 ehydro #6
On the right hand console, there is the amber trouble light. Make sure it is not flashing any codes. Otherwise usual stuff. Look for leaks. Make sure the 4x4 actually engages and works. the loader should lift the front end off the ground. Make sure the PTO engages. Check coolant for oil and oil for coolant. Check the front axle oil.
How many hours? Ask when the hydraulic oil was last changed and did they do filters and clean the screen in the sump.
The 300X loader is the smaller one and the 420 replacement. the 300CX is the heavier 430 replacement. As long as you are ok with the 300X capabilities then it is a good loader. I think it is rated for about 900 Lbs.
I'm not really sure on prices these days, but seems like they are creeping up on these machines.
/ Jd4310 ehydro #7
I can't find that loader model anywhere. Ask the seller if he has a manual for it.
/ Jd4310 ehydro #9
Yup, 300x Loader. That style is still in use today.
/ Jd4310 ehydro #10
http://manuals.deere.com/omview/OMW52222_19/?tM=HO
Not much too it. I think there are several manuals for it. The base and hydraulics.
I was looking for info on the 500X loader in question. Are you guys saying this is a 300X despite the photo with the 500X decal?
/ Jd4310 ehydro #11
It is a 300X loader. It looks like a "5" because there is a little piece of the fret from the hose protection wrap hanging down. The 500 series loaders are for the larger tractors.
/ Jd4310 ehydro #13
Same loader on a 4210. Your 4310 hoses are routed incorrectly. 20171110_172547.jpg
/ Jd4310 ehydro
thanks, I would not have known about the trouble lite.
/ Jd4310 ehydro #19
AHH that explains it. Thanks!
Same loader on a 4210. Your 4310 hoses are routed incorrectly. View attachment 638013
hmm, something to check out. Thats why I love this place,
Are those hoses on a check valve or is there a valve you need to close to reroute them?
They connect with a quick disconnect but it looks like they are just tied on the wrong side of the upright. I imagine you can just cut the tie and reroute them without having to do anything else.
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
