Snow Plow Woes
   / Snow Plow Woes #11
There is no need to slit a steel pipe.
Just weld the tabs on and attach it in front of the cutting edge.
Agree, I did the same thing.
   / Snow Plow Woes #12
Some folks use these.
[video]https://www.homedepot.ca/product/snowbear-38-inch-heavy-duty-skid-shoes-for-snowplows/1001102721?eid=PS_GOOGLE_D28%20-%20E-Comm_GGL_Shopping_PLA_EN_Outdoors_Outdoors_PLA_EN_ _PRODUCT_GROUP_pla-416433435590&gclid=EAIaIQobChMI8tHi6bCN5wIVyZ-zCh0kLwTZEAQYASABEgKJk_D_BwE&gclsrc=aw.ds[/video]
Standard plow shoes. I have those on mine & they help a bit, but not enough. Our ground doesnt always freeze up. So you are left with soft dirt or gravel that plows easily. Shoes are part of the solution, but they can't cary the weight of the plow, loader, possibly the front of the tractor on softer roads. You need float on the plow so they are only carying that weight, which is still to much at times. Then you add the rounded pipe "cutting" edge to the equation.
   / Snow Plow Woes #13
Haven't used an FEL-mounted blade, so I've never really though about this problem until now. If it's such a known issue, as it seems to be, and if the smart guys here on TBN have come up with effective ways to address it, I'm wondering what good fabricators like MTL in Georgia and Everything Attachments in NC say about. :confused:
   / Snow Plow Woes #14
I'm not sure those guys know what "snow" is?
:D
   / Snow Plow Woes #15
:D
True to some degree I bet. But a lot of it is the intended usage too. A lot (most?) SSQA plows tend to go on skid steers plowing parking lots. Skids & especially flat paved parking lots dont need the float stuff a tractor on gravel does.
   / Snow Plow Woes #16
Agree with this. But it seems to me that this is a design opportunity for an innovative fabricator like EA and some others. :) My guess is there are lots of crusher-run driveways and outlet roads out there that are plowed by front blades CUTs and Utility Tractors.
   / Snow Plow Woes #17
Landpride has FEL snow blades with 5 degree side float left and right,I just bought one about 2 months ago.
   / Snow Plow Woes #18
How do you like it, which size did you get, and what was the approximate cost of your Landpride? Just looked at the website, and the information is "sparse".
   / Snow Plow Woes #19
When you aren't plowing level ashalt and are out in the country, all these problems of varying terrain crop up. Not really much you can do about it. Even if I don't get all the snow, as long as I don't tear up grass and dirt, that I'm going to have to repair in the spring, I'm satisfied.
   / Snow Plow Woes #20
I love the blade,I got the STB1584,$2500 out the door. There is a feature you can unlock and lock side float whatever surface your plowing on and it comes with very well detailed operators manual.
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
Bucket (A55973)
Bucket (A55973)
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
2021 Bronco 255K XD Welder Generator (A55973)
2021 Bronco 255K...
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
