Hooks on Bucket
/ Hooks on Bucket #61
I have just used the Bolt on hooks that you get at Harbor Freight. They are not grab hooks but work great. I have had them on 3 tractors. The good thing is that they are about $10 each with bolts included. A 2" receiver in the middle is a nice addition as well. Gives you all the flexibility you could ever want.
I attempted to find those hooks but was unsuccessful. Would you be kind enough to post a link?
Thanks,
Don
Those may not be as strong as the Horrible Fright specs say that are-imagine that LOL. And yes that's the hooks that bent, not the bucket:
/ Hooks on Bucket #62
There have been many copiers of the original Toyota hooks. I wonder if the originals are stronger than the copies.
Copy:
Bruce
/ Hooks on Bucket #63
Before I knew better, decades ago I used two of those 10k tow hooks, spaced about 4 feet apart on the bucket, bolted on without backup plates. They were the only option I could find to bolt on.
Worked fine until I used both hooks to centralize a heavy lift with one chain at the center of the bucket. (Y formation) The hook mounts weren't wide enough for the resulting side pull so it bent the bucket sheetmetal under the hooks. The height of those hooks compound the problem by putting extra sideload leverage on their mounting surfaces.
Next tractor, I used bolt-ons that were specifically designed for that application.
/ Hooks on Bucket #65
Either buy Kenny's bolt on hooks, or if you can weld, and know what you are doing, buy good forged weld on hooks MADE for that purpose, just like Kenny does and make sure there is sufficient steel under them to prevent bending/tearing your metal. I hate to say it, but a lot of things at Harbor Freight are made out of peanut butter. Seriously.
This is an example. I am not saying you need to buy them at Amazon, but this will give you an idea. I buy mine at a big local hardware store in Harrison Ar.
(Pack of 4) 5/16" Weld-On Forged Clevis Grab Chain Hooks - Grade 7: Amazon.com: Industrial & Scientific
/ Hooks on Bucket #66
We sell plenty of weld-on stuff too, in addition to laser cut backing plates.
/ Hooks on Bucket #67
There you go, a one stop shop, either way you want to go. :thumbsup:
/ Hooks on Bucket #68
I had a set of Ken’s hooks on the JD 855 and liked them.
Maybe saving a few bucks is not worth it, but normally I do not lift anything heavy with the FEL. I have forks now for that. Hooks would be handy.
/ Hooks on Bucket #69
iF bolt is good quality and correctly sized it will survive any pulling you can load it with, chain will probably be first place to expect failure.... Welds of hooks (not commercially made and proof tested) probably second place failure will occur...
I am using a 1/4 inch chain proof tested to 1,250 pounds with two bolts rated at 12,000 lbs tensile strength (for each slot bracket or shackle mount) on a tractor the can only apply 1400 pounds ground/traction weight... Don't see my bolts failing, maybe pulling through base material first....
Dale
Very nice idea
/ Hooks on Bucket #70
I sort of did my own thing.... I could make these for about 1/3 the cost of "other" options...
About 2 feet of 2 X 1/4 inch angle iron, 6 bolts (grade 8), 6 nuts, 12 flat washers, 6 lock washers...
Dale
Very nice Idea
/ Hooks on Bucket #71
About 12 years ago I beefed up the top edge of fel bucket with angle iron, and added 3 weld on hooks and a hitch reciever. One of the most useful things I've added to my tractor. Here is a pic of using the center hook today.IMG_20200509_124450440.jpg
/ Hooks on Bucket #72
/ Hooks on Bucket #74
where would I acquire these items ?
I got them at R&R junk store near me , But you could look online they were around $24.00 for both sets pretty cheap... Where are you located ?
2017 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2017 Volvo VNL 760...
(1) 380/85R30 TIRE W/8 LUG RIM (A62130)
(1) 380/85R30 TIRE...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2022 KUBOTA K008-3 EXCAVATOR (A62129)
2022 KUBOTA K008-3...
