Generac Standby Generator Owners?
/ Generac Standby Generator Owners? #1
cold1313
Gold Member
Northern, Ohio
Kubota M4D-071 Kubota F3990
Looking to purchase and install a Generac standby generator for my home.
I was curious who here has had good experience with ordering from XYZ and having the unit shipped direct? Price, service, etc.
/ Generac Standby Generator Owners? #2
I bought from northern tool, 22k unit with battery and oil warmer and $200 rebate card. Came with 10 yr warranty but w/o transfer switch as my 400 amp transfer switch was installed when I built. Free shipping. Had local generac dude install it around $2k He is 6 miles away.
/ Generac Standby Generator Owners? #3
HOLY CRAP! $2000 to install on a house that already had the transfer switch? Did you have it installed in the next county and trench 2/0 cables?
/ Generac Standby Generator Owners? #4
2/0 is not big enough......should be 4/0 ?
/ Generac Standby Generator Owners? #5
Well, 6 miles of cable from his house must be expensive :D
/ Generac Standby Generator Owners? #6
I remember pricing out a diesel generator from a local company, and it was going to cost $10K with another $4-5K for installation. I bought one myself for about $7500, and did my own install for about another $1200 in materials, another couple hundred for equipment rental, and many hours of labor. After going through that experience, I could easily appreciate the $4-5K install cost, especially for a professional company that would already have their own equipment, use licensed workers, and have stricter procedures to follow with codes, inspections, etc. The combination of electrical and mechanical work, plus site prep, trenching etc, make these installs pretty comprehensive. It would have been a little simpler if I put it next to the house, but my generator is about 20-25' away in a small outbuilding.
/ Generac Standby Generator Owners? #9
I thought 2 WAS bigger than 4.
2 is bigger than 4 in standard wire but when you go to the larger cables followed by the /0 then the numbers reverse and the bigger the number the bigger the cable.
/ Generac Standby Generator Owners? #10
Hey, I learned something today....thanks!
/ Generac Standby Generator Owners? #11
~$2,300 to be closer. Because I put it in three years after I built I needed to pull another electrical permit and final inspection (glad to have it inspected). Connecting to the Propane, Electric run all buried, hand dug, drilled through the wall of the house. Professional installation and activation was required for the 10 year warranty.
Sounds like you have done this before and have experience with all of the installation requirements here so yes, I probably paid too much.
/ Generac Standby Generator Owners? #12
it all depends...... electrical and gas permit cost money. A propane regulator cost money. if you used the underground steel wrapped 90 stubs on the gas they cost a good deal. When i install i have to sub out gas because i am not licensed in state for gas. There are only a few companies that even want to do generator gas in my area, as their profit margin is too low to mess with small gas extensions. The last one i had bid i needed less than 15 feet of pipe mounted to wall, a few 90's and a regulator from 2# input to generator... the lowest bid i got was $1,100
I planned on buying the unit direct from a website, as they are cheaper than my local dealer. Have an electrician do the wiring (the local dealer subs it out to them anyway)
Unit will sit next to the house, so it's an easy mechanical install.
Just curious if people have shopped around and found the best price.
/ Generac Standby Generator Owners? #14
Actually that is only 100 amps, so depending on the wire,
a #2 could be more then sufficient.
2/0 aluminum is rated for around 135 amps,
4/0 aluminum is 180.
/ Generac Standby Generator Owners? #15
My cable was TCER7-16 Composite Cable
/ Generac Standby Generator Owners? #16
i can care less if my customer buys their own generator or gets it thru me. I dont make squat on the unit. I only supply them as a courtesy. My money comes thru the installation parts and labor. When i give a bid the line items for generator are spelled out. But if the homeowner supplies the generator it HAS to be located on the gen pad and off the pallet and un-crated before i arrive. When i supply the generator i have a small charge for delivery to site, moving to install location, uncrating and setting unit. Those units weigh about 500 pounds.
I have a special delivery cart that cost me about $1,000. it allows 1 man to move and set generator. I don't bring that to a job unless i supply generator.
Generac DOES NOT require a GENERAC dealer to do service in order to protect warranty. Even a homeowner can do their own work with proper record keeping to prove work. HOWEVER it DOES require only a GENERAC TRAINED service tech to do any repairs that require generac to supply parts and labor. This is the same as most companies paying a dealer to repair their units.
Theres more parts than you think that go into a generator installation. I cant tell you how many times ive had customers tell me that they cant believe how much work and parts it took to complete the job. "No wonder it was so expensive".
In my own case, i've been told by several potential customers that my install price is too high. and to those i politely tell them good day. I never do check back to see how the job went. But i did get called back to 1 job that i had bid years earlier for a service call on a non working generator. The install was so poorly done, i refused to do the repair. The wires feeding house were too small, the gas piping to unit was WAY to small and they never increased the size of the gas meter to accommodate the generator,.I told them to call back the original installer to fix it. I can tell by the sour look that he probably did the job himself.
/ Generac Standby Generator Owners? #17
Generac TCER7-16 cable;
3) #3 (1) #6 (6) 18AWG
Will work for up to 100 Amp installations
What do you find to be the most over looked or unplanned items/expense/work that the DYI guys run into? Instead of having you do the install?
/ Generac Standby Generator Owners? #19
Since the 22k generates roughly 92 amps, I guess that will do just fine.
/ Generac Standby Generator Owners? #20
Learn something new everyday. Don’t think I would change the way I did this one. I like the local Generac guy and everything is working great so far.
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2013 BOMAG BW211D SMOOTH DRUM ROLLER (A67714)
2013 BOMAG BW211D...
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft. Insulated Bucket Truck (A66736)
2012 Freightliner...
2007 CHEVROLET SILVERADO 1500(INOPERABLE) (A67714)
2007 CHEVROLET...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2015 PETERBILT 320 6X4 T/A CNG GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
