Generac Standby Generator Owners?
/ Generac Standby Generator Owners? #21
What do you find to be the most over looked or unplanned items/expense/work that the DYI guys run into? Instead of having you do the install?
Boy, that’s a hard one to answer. Ive seen some that were installed as well as a professional, and others that were....” what were they thinking”. I saw one air cooled unit installed in a garage with a vent cut into the wall. Death trap.
Mostly I see units installed too close to an opening of a house. Ive see a few installed with shed covers that were so low I couldn’t open the top of the generator. I went to one a few weeks ago that had a cover and sealed front to keep snow off of unit. I could not even get to the front opening to change the oil.
Electrically I see a lot with too small of wires run from generator to transfer switch. I had to replace a control panel on a brand new unit because homeowner ran all 6 control wires using red #12 THHN wires.... and got a few crossed. Shorted control panel... a nearly $500 mistake.
I replaced a starter on a new unit because homeowner kept trying to start unit over and over..... didn’t turn on the gas.
I always pour a concrete pad for my installs. I see lots of units sitting on gravel. These tend to sink here in Pacific Northwest. Unlevel units have issues with oil flow.not to mention it sucks to drain oil when motor is lower than drain pan.
/ Generac Standby Generator Owners? #22
^^^ What a great resource for TBN readers.
I appreciate just being able to put a question out there.
/ Generac Standby Generator Owners? #23
I purchased my 20kw unit from a local Generac dealer and he did excellent install. He recommended a whole house surge/lighting protector at the same time which I did.
NG Co. changed to larger meter n/c, local plumber did the gas line work $200 ?
I think total cost of everything was under 5k when all was done 6yr ago.
NOW, here's the kicker. When I called him to come back and do some mechanical, he said he could not because he's tried several times to get Generac to send him to mechanical training and they refused.
A lot of dealers are qualified to install and are good at it, but when it comes to mechanical it's out of their ballpark, not allowed.
Generac wants the valve clearance checked/re set @ X amount of hours. Back then the closest Generac tech qualified to do mechanical was 57mi away and charges mileage both ways. I think there was maybe 5 installers, but zero mechanical in my area.
Since then there is one listed in my area to do mechanical but never returns the calls I've made to get him out to give my unit a once over. Total waste of time.
If/when I replace this unit, I will make sure the contractor is qualified to take care of the whole unit not just 1/2 of it.
If not I will keep looking elsewhere at other brands in a heartbeat.
So when you choose an installer, make sure they can take care of both electrical and mechanical before you sign on the dotted line.
It will save you a lot of frustration. I wish I'd been more aware of that.
/ Generac Standby Generator Owners? #24
Since then there is one listed in my area to do mechanical but never returns the calls I've made to get him out to give my unit a once over. Total waste if time.
Something is wrong here. GENERAC PLEADS with dealers to take the service class. I got phone calls from my sales rep asking me to take the classes. Air cooled class is 4 days and costs about $600-800 plus travel, room. Plus having to purchase about 3-4 grand worth of parts for dealer stock. Maybe your guy didn’t want to purchase parts and pay for class. I have never heard of anyone not being able to take a class.
Heck, GENERAC home office is based in your state.
/ Generac Standby Generator Owners? #25
How true, you'd think WI would be flooded with both sales & service contractors but not so. I just checked Generac website to locate dealer, and within 75 mi there are 16 listed as Sales, but out of that 16 only 6 are also listed as Service. I,m telling you, it's like pulling hens teeth to get service.
My closest in 1mi away but don't return calls. 2nd is 28 mi away and he jacked me around for 3mo before I told him never mind, After that they are from 47 to 68mi for service. Ridiculous !!
/ Generac Standby Generator Owners? #26
Maybe drop by the one that is 1 mile away?
/ Generac Standby Generator Owners? #27
Holy cow. I know I can stay busy as I want to be doing generator service. Now that I’m retiring from electrical I plan on just installing a few new units per year and doing service only. my business is word of mouth mostly. I Service someones unit, they tell their friend, etc.
I personally won’t service liquid cooled units because I don’t want to be an auto mechanic. It’s a 5 or more day class for each series, plus multi thousands in parts. I’ll stick to air cooled.
/ Generac Standby Generator Owners? #28
How I wish you were in my area.
I tried the dropping by once, no one there, already out on jobs I guess.?
/ Generac Standby Generator Owners? #29
LOL, couple years back I was offered a Generac set that had ,like 0 compression.
I offered $50 since I believed I could couple to my tractor.
Turned out the valve stems were worn out hence the 0 compression.
As of today it still puts out its advertised power.
/ Generac Standby Generator Owners? #30
Decide if you need the cold weather package.
If you are running propane, you might need an extra tank to get enough vaporization to supply the unit in extreme cold. That was what my dealer told me.
BTW, my estimate was around $8-9k installed so I decided to go cheap. Bought a dual fuel Champion 7500 watt unit ($850), my propane supplier will run the line ($300) and a contractor will install a transfer switch that feeds to the mains. It will not be "automatic" but simple and affordable. I am going to build a small shed to house it, as well as a spare 5000 watt Generac gas unit that I have used for 20 years. The shed will have doors that can be left open and powered ventilation. Cost for the shed will be about $300. Total cost should come in at less than $2.5k
I really wanted a whole house automatic standby. Install and operating costs were more than I could justify. I do not need continous power during an outage and normally operate for an hour every 4-6 hours. And I did not get a warm fuzzy feeling from the local supplier.
Good luck with your install.
I've wondered about the propane tank, it's 500gal. The only propane usage I would have would be for my furnace emergency heat if my geothermal decides to go. When I initially kicked around this idea a few years back, neither to propane supplier or the Generac dealer seemed concerned.
/ Generac Standby Generator Owners? #32
Our electrician went with Gentron inside stuff for our Isuzu diesel generator from Maine (a real gem diesel). We went with a whole new 200 amp Gentron panel with 4 or 6 little electronic boxes to monitor 4 or 6 breakers to determine whether the generator has enough space to let them come on. Works great. Have one water heater and clothes drier on a couple of those. Has been in service since about January of 2013.
Ralph
/ Generac Standby Generator Owners? #33
And what is so hard about that? :confused2: Anyone with some mechanical experience can do job!
Sure, but your messing with the warranty
/ Generac Standby Generator Owners? #34
Actually your not. Any homeowner can adjust the valves and not affect warranty...unless they mess it up and wreck the unit. Generac actually specs valve clearance in the owners manual. The only issue is if its done incorrectly you can wreck the generator. Personally if i have never adjusted a valve before i certainly would not want to experiment with a $5,000 generator. I include valve adjustment free with the first years inspection and oil filter and oil change for my new customers....just so they dont either neglect it or do it themselves.
its as pretty simple procedure.....but im sure glad that Generac's new generators are going to start using Hydraulic valves. Their 13 and 16KW units already have them. I hear they are product testing 22kw units with them now...hope thats not just rumors. I personally get tired of adjusting them
Good to know!
What are your thoughts on propane tanks, as mentioned above? I'm not confident that my local dealer knows a lot about it...
/ Generac Standby Generator Owners? #36
Not sure how cold and damp you get, but I ran my old generator on a 500 gal above ground tank for 19 years. The new generator went in with a 1,000 gal buried tank. I never have had any gas issues ...ever. And I’m in north idaho. Just got 8 inches of snow today
We get fairly cold and wet here in Northern Ohio but I can't imagine it's nearly as bad as Northern Idaho. I'm going to call the propane company to come out and see if the line is big enough and pick their brain on the tank size. I "rent" the tank, so it doesn't matter to me. I have a 500 gal at the moment, above ground.
My dealer emailed back and stated they are not doing any winter installs until Spring....what the heck.
Guess I'll go to the next one on the list!
/ Generac Standby Generator Owners? #39
Im not doing any installs till spring either. I lose too much time and money fighting the weather to make it worth while. Ive had people call me in December wanting to install a generator ...after i gave them a bid in May. Why should i suffer working outside in 10F weather putting in the unit because they waited until winter.
Mind you, i have never heard anyone complain when i tell them it will have to wait until spring. they usually understand. I now have 4 units scheduled for spring installation.
I'm used to contractors working year round. Especially with our above normal "winter" so far. Many weeks in the 50's. Not much below 30. Really no snow to speak of. Then to be told "we're pretty backed up for the Spring already"....I guess I would take work when I can.
