R1 vs R3 or 4 Traction
/ R1 vs R3 or 4 Traction #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
If there ever was a question, I have proven it on my 2400. Bought it with R4s, replaced with R3s, and now have R1s on the rear and traction is night and day and I removed a pair (had 2 pair now only 1) of rear weights I used on the 1s and 3s. Other thing is that I can run 10 psi (for a softer ride) with the R1s and the 3s and 4s would slip on the rim at that air pressure.
/ R1 vs R3 or 4 Traction #2
Well heck now if you settle green vs orange and Ford vs Chevy then we can close TBN. By the way it’s orange and Ford and both my tractors have R4s:)
/ R1 vs R3 or 4 Traction #3
Great, Texasmark! Now whenever the issue comes up in the future, we can all just link to this thread and save the bandwidth! :laughing:
Sounds like a plan. Seems to me that the purpose of forums is to inform the uninformed and save them the cost and frustration of having to reinvent "the wheel".....er ah in this case, which tire to put on/order on their next tractor purchase, or what works for which application. I'm a farmer and the 2400 is the only tractor I ever had with R4s (was what the dealer stocked when purchased) and is the last. I know I consult forms for that purpose and they work for me.....big time.
/ R1 vs R3 or 4 Traction #5
So, it seems that R1 is great for AG work, not so good for lawn work. R3 is great for lawn work, not so good for AG work, and R4 is a compromise between the two and master of neither AG or lawn work.
I have seen pictures of a compromised tire, don't have the nomenclature, that is an R4 but every other (staggered) lug is missing, giving you the spacing needed between lugs to grip soft soils while plowing, yet giving you the constant road contact of the R4. Then there is the R! with the complex shaped lug for best traction at the tips yet best road contact in the mid section, and radials vs bias for even better traction and on and on.
/ R1 vs R3 or 4 Traction #7
Would it be these that you are talking about (R14)
Titan International - R14T Crossover Tire for Compact Tractors
/ R1 vs R3 or 4 Traction #8
Heck! You might still end up with Radial R1 tires. :laughing:
/ R1 vs R3 or 4 Traction #9
We figured that out back in '98 when this site started. New Holland Blue and Dodge/Cummins!
Although back then I had a Kubota and a Farmall A; I still am partial to old Farmalls.
During a software upgrade in 2000, a bunch of us oldtimers had our '98-99 join dates reset. Back then there was only about 75 people on the forum... It was a Kubota site back then.
/ R1 vs R3 or 4 Traction #10
Well that's simple enough. Going by main use, it's Ag R1's for traction in the field, Turf R3s for the lawn, and Industrial R4s for a compromise.
So is it best traction? Least damage? Or compromise? At least we get a choice.
As for use on slopes, well.... I prefer not to be there at all. Though if I have to go there I'll go with R3 turf tires. Not because turfs are so wonderful on slopes, but because both the other choices are worse - being narrower, higher, and with less side resistance.
BTW, I run 8 to 12 lbs pressure in the rears, work them hard, and never have had a tire slip on a rim.
rScotty
/ R1 vs R3 or 4 Traction #11
rScotty
Tubeless with "beet juice" tends to become a problem at low pressure in R3/4 profiles. And once it creeps a little its hard to stop.
It has been reported several times.
/ R1 vs R3 or 4 Traction #12
Good to hear from someone with actual experience rather than just conjecture without any real first hand experience with all three.
It would be interesting to see where Titan's R14T hybrid tires fit in. Interesting concept, but then again, everything is a compromise. I am a dedicated user of R1 tractor tires. However, if the R14T tires had been available about two years ago when I purchased my new Kubota, I may have given them a shot.
/ R1 vs R3 or 4 Traction #13
Sounds as though R3s up front with R1s in the rear might be the best: best rear and front traction. Wonder if we can all get a matched set so the fronts don't over rotate much. Get most heavy duty R3s as possible if doing FEL work.
Ralph
/ R1 vs R3 or 4 Traction #15
Most of my tractor work is with snow.
Now I ask, which tire resembles a snow tire the most?
My turf's serve me very well!
I've had tractors with all three types of tire - both compact and utility size to 100hp.
I like industrial tread on the larger loader tractors, turf tires on the smaller up to about 35 hp.... and Ags for plowing. Yes, the turf tires do require chains in ice and snow, but then most any tire style benefits from chains in ice and snow. There just aren't any simple correct answers for tire style. Too much depends on your own land and how you like to use a tractor.
rScotty
/ R1 vs R3 or 4 Traction #16
It matters a lot what the snow is on and how deep. I have backed up a 17 degree hill carrying a 12" tree in more than a foot of snow on turf. --- Ags.
On a smooth consolidated surface and much lighter snow the smoother tread profile of R3,4 has an advantage in static - non slip - traction. . . . But Ags tend to always be able to claw thru.
/ R1 vs R3 or 4 Traction #17
^^^ What he said!
And you could read the entire site (or keep up with new material) in one setting.
Now, I don't even try.
/ R1 vs R3 or 4 Traction #18
Oh No!! Now Piloon, rScotty and Spyderlk have done it. Here we go again with which tire is best. :laughing:
I thought Texasmark's whole purpose in starting this thread was to lay the issue to rest for everyone, once and for all! ;) :D
/ R1 vs R3 or 4 Traction #19
The answer all are seeking is simple;
One only needs multiple tractors with different tire setups for the kind of work they do with each tractor. :tractor:
/ R1 vs R3 or 4 Traction #20
That works.
Tires roll.
2005 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2005 Dodge Ram...
2014 Dodge Charger Sedan (A61574)
2014 Dodge Charger...
(2) 25X10.00-12 TIRES W/ 4 LUG RIMS (A64280)
(2) 25X10.00-12...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
(2) 460R85R38 TIRES W/ (8) LUG WHEELS (A64280)
(2) 460R85R38...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
