R1 vs R3 or 4 Traction
   / R1 vs R3 or 4 Traction #11
Well that's simple enough. Going by main use, it's Ag R1's for traction in the field, Turf R3s for the lawn, and Industrial R4s for a compromise.
So is it best traction? Least damage? Or compromise? At least we get a choice.
As for use on slopes, well.... I prefer not to be there at all. Though if I have to go there I'll go with R3 turf tires. Not because turfs are so wonderful on slopes, but because both the other choices are worse - being narrower, higher, and with less side resistance.
BTW, I run 8 to 12 lbs pressure in the rears, work them hard, and never have had a tire slip on a rim.
rScotty
Tubeless with "beet juice" tends to become a problem at low pressure in R3/4 profiles. And once it creeps a little its hard to stop.
It has been reported several times.
   / R1 vs R3 or 4 Traction #12
If there ever was a question, I have proven it on my 2400. Bought it with R4s, replaced with R3s, and now have R1s on the rear and traction is night and day and I removed a pair (had 2 pair now only 1) of rear weights I used on the 1s and 3s. Other thing is that I can run 10 psi (for a softer ride) with the R1s and the 3s and 4s would slip on the rim at that air pressure.
Good to hear from someone with actual experience rather than just conjecture without any real first hand experience with all three.
It would be interesting to see where Titan's R14T hybrid tires fit in. Interesting concept, but then again, everything is a compromise. I am a dedicated user of R1 tractor tires. However, if the R14T tires had been available about two years ago when I purchased my new Kubota, I may have given them a shot.
   / R1 vs R3 or 4 Traction #13
Sounds as though R3s up front with R1s in the rear might be the best: best rear and front traction. Wonder if we can all get a matched set so the fronts don't over rotate much. Get most heavy duty R3s as possible if doing FEL work.
Ralph
   / R1 vs R3 or 4 Traction #14
Most of my tractor work is with snow.
Now I ask, which tire resembles a snow tire the most?
My turf's serve me very well!
   / R1 vs R3 or 4 Traction #15
I've had tractors with all three types of tire - both compact and utility size to 100hp.
I like industrial tread on the larger loader tractors, turf tires on the smaller up to about 35 hp.... and Ags for plowing. Yes, the turf tires do require chains in ice and snow, but then most any tire style benefits from chains in ice and snow. There just aren't any simple correct answers for tire style. Too much depends on your own land and how you like to use a tractor.
rScotty
   / R1 vs R3 or 4 Traction #16
It matters a lot what the snow is on and how deep. I have backed up a 17 degree hill carrying a 12" tree in more than a foot of snow on turf. --- Ags.
On a smooth consolidated surface and much lighter snow the smoother tread profile of R3,4 has an advantage in static - non slip - traction. . . . But Ags tend to always be able to claw thru.
   / R1 vs R3 or 4 Traction #17
We figured that out back in '98 when this site started. New Holland Blue and Dodge/Cummins!
Although back then I had a Kubota and a Farmall A; I still am partial to old Farmalls.
During a software upgrade in 2000, a bunch of us oldtimers had our '98-99 join dates reset. Back then there was only about 75 people on the forum... It was a Kubota site back then.
^^^ What he said!
And you could read the entire site (or keep up with new material) in one setting.
Now, I don't even try.
   / R1 vs R3 or 4 Traction #18
Oh No!! Now Piloon, rScotty and Spyderlk have done it. Here we go again with which tire is best. :laughing:
I thought Texasmark's whole purpose in starting this thread was to lay the issue to rest for everyone, once and for all! ;) :D
   / R1 vs R3 or 4 Traction #19
The answer all are seeking is simple;
One only needs multiple tractors with different tire setups for the kind of work they do with each tractor. :tractor:
   / R1 vs R3 or 4 Traction #20
That works.
Tires roll.
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
1272 (A50490)
1272 (A50490)
David Bradley Manure Spreader (A50515)
David Bradley...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2013 TIGER CAT 720E WHEEL FELLER BUNCHER (A51242)
2013 TIGER CAT...
