Texasmark
Elite Member
- Joined
- Apr 24, 2012
- Messages
- 3,758
- Location
- N. Texas
- Tractor
- Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
Interesting. I have slopes on pond dams running a ⅓ or better slope. Initially mowed with a tractor and R1s but didn't feel comfortable....rollover worry. Went to lawn mowers which came with turfs and they just lost it, both conventional riding and ZT....don't mow these with a tractor any longer.Well that's simple enough. Going by main use, it's Ag R1's for traction in the field, Turf R3s for the lawn, and Industrial R4s for a compromise.
So is it best traction? Least damage? Or compromise? At least we get a choice.
As for use on slopes, well.... I prefer not to be there at all. Though if I have to go there I'll go with R3 turf tires. Not because turfs are so wonderful on slopes, but because both the other choices are worse - being narrower, higher, and with less side resistance.
BTW, I run 8 to 12 lbs pressure in the rears, work them hard, and never have had a tire slip on a rim.
rScotty
Went from turfs to bar lugs on the mowers and they did ok up and down but not side (parallel) running. One area has trees right at the base of the slope so you have to parallel mow. Went from 12" dia wheels down to 8" with the same 23" OD using studded snow tires with soft sidewalls, running 5-10 psig and solved the problem and moving on to the large balloon deliberately created by changing wheel diameter got a soft ride mowing pasture perimeters.
ZT mower weighs about 1200# and it holds just fine. Main reason for using the mower rather than the tractor is that the mower has a low CG and wide frame as compared to the tractor having the opposite and I wasn't going to run the wheels out on a tractor just to mow that dam making it basically useless for it's intended purpose.
