cstamm81
Gold Member
- Joined
- Aug 10, 2009
- Messages
- 360
- Location
- Leesport, PA
- Tractor
- Kubota L5740, Mahindra 3016HST, Kubota F2880
Hi guys, I thought I壇 throw this out there and see if anyone has any experience with a project of this nature. I知 collecting parts to build a crane attachment, primarily for picking up large rounds of firewood and short logs. I scored an old school Blackhawk engine crane the other day, rated at 2k lbs, with a manually extendable boom arm.
The plan it to replace the porta power driven cylinder that raises and lowers the boom with a 2 way cylinder, powered by a hydraulic power pack. Then, I値l mount a winch on the top of the boom, and weld a sheave on the end of the boom arm.
Ideally, the crane would be able to be mounted to a trailer or the bed of a truck. Where am I struggling is trying to come up with an easy, safe way to allow the crane to rotate. It appears the cheap truck cranes simply rotate on a pipe inside of another pipe so to speak. I feel like with a heavy load, there痴 going to be a lot of friction to rotate the crane, especially if the ground is uneven.
I see heavy duty turntables out there, but I can稚 imagine they are designed for anything but a load pushing directly down on the plate. With a tall crane, there痴 going to be a lot of leverage and this force pulling sideways on the base. Ideally, I could electrically or hydraulically rotate the crane, but I致e yet to come up with an easy / cheap to use way to accomplish this.
Anyone have any experience with a project of this nature? The Chinese made cranes available at say harbor freight look cheesy to me, and the next step up in quality gets expensive really fast. Hoping to build something robust and very capable for much less. Thanks in advance.
