JD855 Drawbar
/ JD855 Drawbar #1
Can anyone advise me how a drawbar is connected to the slot beneath the transaxle on this machine. I use a towball on a towing A frame on the 3 point hitch, but now require a towing setup that has a lower centre of gravity and releases the 3 point hitch for other uses.
/ JD855 Drawbar #2
Does this help?
/ JD855 Drawbar
Very helpful, thank you.
Do you have a key to explain the numbered parts?
/ JD855 Drawbar #4
Tom
You can go to the JD parts, put in model 855 and all the parts schematics are available.
John Deere Parts Catalog
Hope that helps.
What part(s) are you missing?
/ JD855 Drawbar
Thanks for the replies. I have lots of information there to fuel my research. I need to examine the underside of the transaxle to see exactly what is currently in place so that I can figure out what I need to get.
/ JD855 Drawbar #8
All you have to do is stick the drawbar in and line up the holes then put a pin in it.
I was too cheap to buy a drawbar and I couldn't find any 1" bar stock local so I bought two 30" long pieces of 1/2"x2" flat bar. I welded them together and bored the holes with a bi metal hole saw.
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61567)
2017 Bad Boy...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2022 Kubota Z422-54 Zero Turn Mower (A63118)
2022 Kubota...
2021 John Deere 3046R Tractor Loader (A63116)
2021 John Deere...
