JD855 Drawbar
/ JD855 Drawbar #1
Can anyone advise me how a drawbar is connected to the slot beneath the transaxle on this machine. I use a towball on a towing A frame on the 3 point hitch, but now require a towing setup that has a lower centre of gravity and releases the 3 point hitch for other uses.
/ JD855 Drawbar #2
Does this help?
/ JD855 Drawbar
Very helpful, thank you.
Do you have a key to explain the numbered parts?
/ JD855 Drawbar #4
Tom
You can go to the JD parts, put in model 855 and all the parts schematics are available.
John Deere Parts Catalog
Hope that helps.
What part(s) are you missing?
/ JD855 Drawbar
Thanks for the replies. I have lots of information there to fuel my research. I need to examine the underside of the transaxle to see exactly what is currently in place so that I can figure out what I need to get.
/ JD855 Drawbar #8
All you have to do is stick the drawbar in and line up the holes then put a pin in it.
I was too cheap to buy a drawbar and I couldn't find any 1" bar stock local so I bought two 30" long pieces of 1/2"x2" flat bar. I welded them together and bored the holes with a bi metal hole saw.
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL8DL188033 (A61165)
INOP/NON-RUNNING...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
PALLET OF ARMSTRONG CEILINGTILE (A62131)
PALLET OF...
UNUSED WOLVERINE QC5-26-2DG QUICK ATTACH (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE SB84-84" ROCK BKT (A62131)
UNUSED WOLVERINE...
429872 (A61166)
429872 (A61166)
