3 Point Forks
/ 3 Point Forks #1
Ronaldjaye
Member
Rocky Mount, NC
John Deere 855
I am thinking about getting a 3-point pallet fork to use behind my John Deere 855. Have any of you guys owned and used Them? What are the pros and cons of getting nonadjustable tines or adjustable tines? Come on flood me with your thoughts!
/ 3 Point Forks #2
I have a non adjustable pallet fork for the three point hitch. The non adjustable part is not an issue the majority of the time. For me it would not be a deal breaker. What I find frustrating is that they don't lift high enough to put a pallet in the back of a pick up. I can run the tractor onto a trailer and get onto the pick up that way but it's time consuming. They are very handy for running pallets up into a trailer and moving heavy rocks etc. Someday when I'm bored I'll either make these ones attach to the fel or I will build a different set for that.
/ 3 Point Forks #3
I have a fixed fork set I got from Agri Supply...very well made...
I knew they would not lift high enough for many things that would make them ideal but I mostly use them for moving firewood and other tractor attachments...lots of unconventional uses too...
A friend just gave me 4 nice plastic pallets...unfortunately the fork slots are about 2" too narrow to use...:(
/ 3 Point Forks #4
I have the Deere forks that are adjustable, and adjust them fairly often. Wide if carrying logs.. in between to match with pallet differences, and close together if digging out rocks or roots. Many different uses for forks. I made my FEL forks to fit my JD iMatch quick hitch and added the hyd. top link. I move pallets of firewood in the winter with the 3 pt forks when my Western blade is on the front of the Deere (FEL off).
/ 3 Point Forks #5
Well, the adjustability is the big thing with them to make them more than just pallet forks.
I've used a single center tine on mine to function as an attachment for a boom pole to install 21- 32' trusses for the pole barn. Setting up a six foot work platform for the trim the widest setting was good and stable. I've used the bare frame as a bushhog probe, in uncharted territory where the six foot bucket would peel off areas of sod--they scrape and bump but don't cut. I installed chain hooks on the sides and now implement moving is a snap--except for the logging winch and wood chipper--they need a narrow setting to fit between the implement 'feet' before chaining on. A narrower setting works well to lift 4-wheelers up onto the truck for oil change and service (gets me off the ground!). The widest one is really needed to get the truck sander on and have it be stable for my tractor. I tried the single tine for popping stumps--doesn't work, but allows you the single center probe, which probably could make a narrow trench--a friend used his to install underground cable doing it & said it was a snap.
I bought removable and adjustable, because of the variety of configurations, support structure and compactness of the bare frame gave me options for putting the tine exactly where i wanted it, instead of having to bridge the gap or lay out a support structure onto fixed forks.
Cons--they do rattle and shift--they make noise when bare and on the move. You must keep the track clean and everything lubricated or adjustment is challenging, tines are heavy and awkward to move when detached, the bare frame is heavier.
I wouldn't look at a fixed set--forklifts have adjustment built in. I'd get removable ones too--whole setup can be stored in a 1'x 5' strip if necessary--they usually sleep under the winch intact though.
Weight rating will affect pricing, so don't get hung up on the 'strongest set' if your tractor can't approach its limit. They're on everything from 20hp-100+, so shop according to application. Good luck!
Sorry--you're looking for the three point set-up. On a FEL there's a bunch of uses--less so off the back.
/ 3 Point Forks #6
With 2 extra pins and a top link hook .... why would they not work on both front and back ?
/ 3 Point Forks #8
What are you planning on using them for? Do you have a loader on the tractor? If you have a loader, I highly recommend having a fork set up made for it. You won't believe how many uses you'll find for them. Mine is on almost all the time over the bucket.
/ 3 Point Forks #9
This would work nicely on the rear of your tractor;
3PT Scissor Lift
These are a scissor type lift which will get you a greater range then simple rear mounts.
There are also some conventional type 3 point forklifts available.
/ 3 Point Forks #10
/ 3 Point Forks #11
I've been using the following set from Titan Attachments on my Deere 855 MFWD for several years:
3 Point Pallet Fork Attachment Category 1 tractor carryall
They work great, with two exceptions:
1. The lifting power of the 855 is a little light for many pallet-moving jobs. I think it's well under 1000 lb. at 24" off the pins.
2. I don't have a third hydraulic channel on that machine, which means manual top link. Manual top link means no tilt control on the forks, which is very limiting, there's no way to adjust for sag while lifting.
In a pinch, it can work, though. I made this system work for odd jobs for several years.
/ 3 Point Forks #12
The JD forks were modified for the 3pt iMatch hitch with the addition of two top plates (A and B) for the top hook and a solid bar (C) across the bottom for the lower hooks to catch. I've picked up and moved double pallets of firewood (figure 40% of a full cord around 1800 lbs). The hyd top arm is essential for this to work well, and work well it does.
2007 KEYSTONE COPPERS CANYON 5th WHEEL CAMPER (A60736)
2007 KEYSTONE...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
2019 GALYEAN...
PALADIN INDUSTRIAL SCREENER (A60736)
PALADIN INDUSTRIAL...
72'' Root grapple (A61567)
72'' Root grapple...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
