Snow Equipment Owning/Operating Greasing (or not) snow chute rotating base?
/ Greasing (or not) snow chute rotating base? #1
jpilk99
Gold Member
Bolton, MA
1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
I have on older Husqvarna 10/30 snowblower with 鍍hreaded screw adjustable base to rotate the direction of the snow chute. I知 pretty sure when I bought the machine, (used), 6 or 7 years ago that it had grease in and around the moving or contacting surfaces where it rotated. I noticed a few times over the years that I couldn稚 rotate the chute and it seemed the threaded screw adjuster was frozen. Or the surfaces themselves of the chute or the base it rotated on were frozen together. If I put a heat gun to these areas, after a few minutes, it freeed up.
So I took all these elements apart, cleaned them, and then applied Lithium grease. But sure enough, it痴 frozen and bound up again.
Any ideas what I知 doing wrong? I致e used a couple different types of grease (white lithium, regular or gray lithium, spray Teflon...) and nothing works.
Thank you.
Jay
/ Greasing (or not) snow chute rotating base? #2
How much grease are you applying? A light spray coat may not be sufficient. I use a wooden spatula (shingle) to spread grease like cake icing on the chute flange of my snowblower at the start of the season.
Also after you finish snowblowing brush the snow from the machine, especially the chute. It may be that meltwater is finding its way into the mechanism, pooling, and then freezing.
/ Greasing (or not) snow chute rotating base? #3
White lithium at cold temps turns to a stiff wax type consistency. To start out, I would put some good old fashioned OIL in that joint.
/ Greasing (or not) snow chute rotating base? #4
On my CUT chute I made a large plastic 'washer' for the chute to rotate on otherwise it liked to stick.
Also a squirt of oil from time to time helps.
Thanks all. I don't think I'm putting an excessive amount of grease on, but, not exactly sure how much. Maybe a teaspoon all in; plastic disk, gears/teeth, threaded "drive" part...
Sounds like I should clean it all off, then maybe a little oil. I'll also try and clean off snow when done. But this morning, after is was nice and clean - but 4 degrees - it seemed the frost was frozen in there. Maybe I just gotta have the ol' heat gun handy at the start of a job. Would be nice to have a heated garage to store it in too :).
Thanks again everyone!
Jay
/ Greasing (or not) snow chute rotating base? #6
Be careful what you wish for. A heated chamber will melt the snow and is nice to work in, BUT Snow blowing with a "hot" snowblower causes problems. The warm metal melts the snow often leading to clogs, etc.
/ Greasing (or not) snow chute rotating base? #7
If you spray any kind of oil on a machine, you will attract dirt and that will need to be cleaned off. I kind of see that as worse than the problem you are trying to fix.
/ Greasing (or not) snow chute rotating base? #8
I’ve heard of a guy cutting a washer out of a plastic bucket lid that worked pretty good.
/ Greasing (or not) snow chute rotating base? #9
I wondering and or thinking this is a storage and temp issue over a particular grease. If the machine is stored where their is freeze thaw I could see things getting frozen when it’s time to use it. If the storage can’t be changed (like putting it inside) I’d be inclined the grease very heavy between the two surfaces that seem to freeze. I’d bet it’s between the chute and blower body. That’s typically a flat flange that would love to freeze the two together. But it might be a different spot.
/ Greasing (or not) snow chute rotating base? #10
That is why it is good to have the mating surfaces oily so it repels moisture so it doesn't freeze. That is why I greased my blower chute pivot with marine grease.
/ Greasing (or not) snow chute rotating base? #12
I've always had good luck with the white lithium grease. It has been used in automotive applications for a long, long time. The big trick with snow blowers, is to keep them inside as much as possible. The paint quickly gets worn off and the bare metal surfaces get semi-polished just like a mold board on a plow or a disc. If you allow the metal to set out it will eventually rust and pit, then you can have problems. I wash my blower each spring and repaint any bare metal I can get to before storing it for the summer inside my barn. Probably disassemble and grease grease the chute rotating area every two years or three with the lithium. That is a good time to hit the chain, PTO shaft, and chute areas with a little lube. Then, next fall, she is good to go for the next winter. No pitted surfaces to slow the movement of snow or cause other problems.
/ Greasing (or not) snow chute rotating base? #13
Thank you.
Jay
On the various walk behind blowers I have used through the years, I never greased or oiled the chute pivot point at all and had no problems. If you are storing the blower in a heated area, the grease may be working against you by holding in the moisture which freezes once you start blowing snow. If you are storing the blower in an unheated area the grease may still be holding in moisture. I would suggest cleaning out all the grease and see what happens. Also, if you have a manual, see what it suggests for this issue.
/ Greasing (or not) snow chute rotating base? #14
When my tractor was delivered, the service person who did the delivery recommended thick heavy grease for the chute rotation gear. Before first use, I filled the area with some marine-rated bearing grease that I had left over from packing the wheel bearings in my trailer. My tractor/blower is stored unheated, and so far so good; the thick grease does a good job preventing any significant amount of water from getting in there. At the end of each season I remove any dirt or other crap that got in there and fill it with grease for storage into next season.
/ Greasing (or not) snow chute rotating base? #15
I use the same "Cleaner Lubricant Preservative", aka, CLP, as I do on my AR 15 weapons, good to a operating range of -65 Degrees F / +475 Degrees F.
KC
24220 (A56859)
24220 (A56859)
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
BUSH HOG 3715 BATWING ROTARY MOWER (A62130)
BUSH HOG 3715...
BUNDLE OF (1) TOPLINK & (2) LIFT ARMS (A62130)
BUNDLE OF (1)...
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A61165)
2002 International...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
