Snow Equipment Owning/Operating Greasing (or not) snow chute rotating base?
   / Greasing (or not) snow chute rotating base? #1
jpilk99
Bolton, MA
1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
I have on older Husqvarna 10/30 snowblower with 鍍hreaded screw adjustable base to rotate the direction of the snow chute. I知 pretty sure when I bought the machine, (used), 6 or 7 years ago that it had grease in and around the moving or contacting surfaces where it rotated. I noticed a few times over the years that I couldn稚 rotate the chute and it seemed the threaded screw adjuster was frozen. Or the surfaces themselves of the chute or the base it rotated on were frozen together. If I put a heat gun to these areas, after a few minutes, it freeed up.
So I took all these elements apart, cleaned them, and then applied Lithium grease. But sure enough, it痴 frozen and bound up again.
Any ideas what I知 doing wrong? I致e used a couple different types of grease (white lithium, regular or gray lithium, spray Teflon...) and nothing works.
Thank you.
Jay
   / Greasing (or not) snow chute rotating base? #2
How much grease are you applying? A light spray coat may not be sufficient. I use a wooden spatula (shingle) to spread grease like cake icing on the chute flange of my snowblower at the start of the season.
Also after you finish snowblowing brush the snow from the machine, especially the chute. It may be that meltwater is finding its way into the mechanism, pooling, and then freezing.
   / Greasing (or not) snow chute rotating base? #3
White lithium at cold temps turns to a stiff wax type consistency. To start out, I would put some good old fashioned OIL in that joint.
   / Greasing (or not) snow chute rotating base? #4
On my CUT chute I made a large plastic 'washer' for the chute to rotate on otherwise it liked to stick.
Also a squirt of oil from time to time helps.
Thanks all. I don't think I'm putting an excessive amount of grease on, but, not exactly sure how much. Maybe a teaspoon all in; plastic disk, gears/teeth, threaded "drive" part...
Sounds like I should clean it all off, then maybe a little oil. I'll also try and clean off snow when done. But this morning, after is was nice and clean - but 4 degrees - it seemed the frost was frozen in there. Maybe I just gotta have the ol' heat gun handy at the start of a job. Would be nice to have a heated garage to store it in too :).
Thanks again everyone!
Jay
   / Greasing (or not) snow chute rotating base? #6
Be careful what you wish for. A heated chamber will melt the snow and is nice to work in, BUT Snow blowing with a "hot" snowblower causes problems. The warm metal melts the snow often leading to clogs, etc.
   / Greasing (or not) snow chute rotating base? #7
If you spray any kind of oil on a machine, you will attract dirt and that will need to be cleaned off. I kind of see that as worse than the problem you are trying to fix.
   / Greasing (or not) snow chute rotating base? #8
I’ve heard of a guy cutting a washer out of a plastic bucket lid that worked pretty good.
   / Greasing (or not) snow chute rotating base? #9
I wondering and or thinking this is a storage and temp issue over a particular grease. If the machine is stored where their is freeze thaw I could see things getting frozen when it’s time to use it. If the storage can’t be changed (like putting it inside) I’d be inclined the grease very heavy between the two surfaces that seem to freeze. I’d bet it’s between the chute and blower body. That’s typically a flat flange that would love to freeze the two together. But it might be a different spot.
   / Greasing (or not) snow chute rotating base? #10
That is why it is good to have the mating surfaces oily so it repels moisture so it doesn't freeze. That is why I greased my blower chute pivot with marine grease.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2019 ISUSZU NPR BOX TRUCK (A56129)
2019 ISUSZU NPR...
Wood Gliding Chair (A53316)
Wood Gliding Chair...
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
Used Oil Tank with Pump (A55787)
Used Oil Tank with...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
