Storage Box for Roll Bar
/ Storage Box for Roll Bar #1
SnagDump
Member
Meadows Valley, ID
Ventrac 4500Z, Bobcat S185 Skid Steer
After carrying my seeder around in the bucket and successfully running it over when it fell out, I decided I needed a more secure place for the new seeder and bags of seed as I traveled around the hilly terrain cultivating and seeding.
The sides are 1-1/8" subfloor material only because that's what I had laying around. They bolt to the roll bar using the holes that are already there for securing the roll bar when it's folded down. The 3 x 3 x 1/4" wire grid material I bought on amazon. I wanted to be able to see through the box at least when I don't have anything in it. Seems to work pretty well so far.
/ Storage Box for Roll Bar #2
Good job, looks great!
/ Storage Box for Roll Bar #3
Good job on that.
/ Storage Box for Roll Bar #4
I looked at the first 2 pictures and thought, "That bungee is never gonna hold that box in place!" :laughing: Looks good man!
Hah! Never noticed that when I took the pics but it sure looks like the bungee is supposed to hold it.
/ Storage Box for Roll Bar #6
Yes its a beautiful thing, but in the even of a rollover, that box corner will dig into whatever material in on the side of the hill you flop over on. If it catches, the machine may be tripped instead of it sliding. If tripped, the tractor will/may keep rolling and go over more that once. That being the case, you may be ejected in spite of a seat belt because the roll velocity is so high. This is a problem discovered on specially equipped PU trucks that we tested when aftermarket head-ache racks, etc are installed. I'd keep the corners inward of the roll bar as much as possible.
/ Storage Box for Roll Bar #7
Nice job! I’ve been wanting to make a chainsaw rack on my ROPS for years and just haven’t done it ....
I can picture the scenario you've described but the box would have to be really strong for that to happen. In my case there's not a lot of wood between the bolt holes and edge of the OSB sideboards and I have no doubt the box would break away as soon as it hit something. It would be something to think about if someone was building a box with steel plate sides though. Thanks for bringing this up.
/ Storage Box for Roll Bar #9
Great job on the box.
I'm curious about the teeth on the bucket. Did you fabricate those, or are they from Ventrac?
It's called a Piranha Tooth Bar and I bought it on the web from an outfit called bxpanded.com. People who have put them on tractor buckets seem to like them quite well and like any tooth bar or toothed bucket they should dig better than a smooth one. Also supposedly helps with clearing brush as the teeth are bevel sharpened on all edges. I say "supposedly" because the ground froze up solid around here just before the bar arrived and I haven't really put it to the test.
/ Storage Box for Roll Bar #11
It sure looks better than the OEM Ventrac tooth option. I'll check that site out.
I'm close to pulling the trigger on the Ventrac. I demoed Ventrac with the 72 inch finish mower and the contour deck, but the dealer did not bring a power bucket. The 72 inch deck did well, but the contour mower performed poorly (almost like it was underpowered and/or the blade velocity was way to slow).
I am curious how well the bucket does with a little light excavating (digging down a foot or so). I know that it is no skid steer, but wonder how well it does in the dirt. Not many videos out there of people digging or leveling ground with it.
/ Storage Box for Roll Bar #12
It sure looks better than the OEM Ventrac tooth option. I'll check the site out. Did you have to drill a couple of holes in the side of the bucket or was it a direct bolt on?
I'm close to pulling the trigger on the Ventrac. I demoed one this fall with the 72 inch finish mower and the contour deck, but the dealer did not bring a power bucket. The 72 inch deck did well, but the contour mower performed poorly (almost like it was underpowered and/or the blade velocity was way to slow).
There are videos of all kinds of things including snowblowing pumpkins but as you noted not much about actual digging with the bucket.
I've only had my machine since July and I didn't get the bucket until fall and by the time I got it and put the tooth bar on things were frozen up. So, I don't have any experience I can share with you at this point. I'll know more in the spring which means late May to June around here.
/ Storage Box for Roll Bar #14
You got to remember the you add length of the tooth bar from the pivot point of the bucket you will loose digging power, they aren't over blessed the way they are. I took the factory ones and welded the end up with 110 -18 and ground them sharp edge. It digs really good now...... jim
2022 New Holland C327 Compact Track Loader (A63118)
2022 New Holland...
Snap-On Zeus Diagnostic Machine (A63118)
Snap-On Zeus...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
2016 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2016 INTERNATIONAL...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
