LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,473
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I was just trying to calculate how much down pressure on the 3pt if tractor pressure was put to a large cylinder. Add that number to the weight of the lift @ 500lbs. The final lift potential might be much more than what is considered safe for the tractor of this size.:2cents:
Tractor Tools Direct - CM 3-Point Forklift - YouTube
Forklifts don’t have down pressure unless it’s one of the 3 wheeled delivery forklifts. Even a little forklift will lift a lot so it’s probably going to wheelie the tractor.
It seems like that big single acting cylinder would need a lot of oil to lift to full height. Is that going to cause problems for your tractor??
I know there is no HYDRAULIC down pressure. I was talking about pressure or weight on the 3pt while lifting an object.
Unless you’re taking the mast off the smallest of forklifts lifting the front of the tractor off the ground will be the weak link. My forklift is pretty hefty for a warehouse model weighing 12,000 pounds but I’ve lifted and moved 10,000 pound loads with it. I attempted a 15,000 pound load which it almost did. And even then it was lifting the back off the ground not stalling the hydraulics. My buddy has a much smaller Toyota that weighs about 6500 pounds and it effortlessly moves 2500 pound pallets. Forklifts are small but mighty.View attachment 628813
No, the 3pt of the OP's tractor might be the weak link. Just because a forklift mast can lift a heavy weight doesn't mean a small tractor can safely support it.
That's a very good point. Single action cylinders deplete the oil. Your tractor doesn't have a huge reservoir, a gallon disappearing into the cylinder can cause your reservoir to run dry.
Install a surge tank to hold the additional oil with an overflow to the system reservoir. It would have to be a closed system.
Ron
