3pt Fork Lift
/ 3pt Fork Lift #1
LFEngineering
Western, MA
Kubota B1700, IH Cub Lo-Boy 185( Sold) & Deutz Allis 5215 (Sold)
I've wanted to build this for years, but never found the right parts forklift. That was until a few weeks ago.
It's a little on the heavy side weighing in at 500lb empty, but I plan on doing some weight reduction in the coming weeks.
The forks offer a 6ft lift height, not including the lift of the 3pt itself.
The forklift cylinder is a single action and my aux circuit is dual action so I plumbed the return line into transmission tank with a spare QD allowing the pressure to dump when lowering.
/ 3pt Fork Lift #4
How much hydraulic pressure do you have available to the fork lift cylinder and what diameter is the lift cylinder?
/ 3pt Fork Lift #5
Not very much because a forklift uses big cylinders and the leverage disadvantage is only 2-1. A tractor operating pressure would be plenty.
/ 3pt Fork Lift #6
That's a rugged looking unit. You will find a lot of uses for it.
/ 3pt Fork Lift #7
I was just trying to calculate how much down pressure (total weight exerted on 3pt from lifting with forks + fork unit) on the 3pt if tractor pressure was put to a large cylinder. Add that number to the weight of the lift @ 500lbs. The final lift potential might be much more than what is considered safe for the tractor of this size.:2cents:
Tractor Tools Direct - CM 3-Point Forklift - YouTube
/ 3pt Fork Lift #8
Nice :thumbsup:
An hydraulic top link is very nice in this application as it allows you to tilt the mast.
That's a very common setup here for the orchard farms to move plastic pallet boxes full of fruit around.
/ 3pt Fork Lift #9
What are you planning on lifting with it? What are your 3pt arms rated at? My kubota is only rated at 1300lbs at the bar, less at 24".
/ 3pt Fork Lift #10
It seems like that big single acting cylinder would need a lot of oil to lift to full height. Is that going to cause problems for your tractor??
1988 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1988 Lufkin...
2007 Ford F-750 Terex Hi-Ranger 5TC-55 55ft. Bucket Truck (A60352)
2007 Ford F-750...
PALADIN INDUSTRIAL SCREENER (A60736)
PALADIN INDUSTRIAL...
John Deere 5055E (A53317)
John Deere 5055E...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2018 FREIGHTLINER...
Mini Excavator Grapple (A60463)
Mini Excavator...
