Just another junk chainsaw
/ Just another junk chainsaw #661
Poulan/Craftsman saws from the 80s are very good saws.
The Poulan Pro/Craftsman chainsaws you find today for under $150 new are gonna be the smaller ones (34cc usually) and with no vibration protection. Even those saws work OK for the occasional user who does not operate it for more than 15-30min at a time, and who actually maintains it. Note that these cheap saws use Walbro or Zama carbs, just like the big boys. They do tend to have plastic pinion gears in the oil pump, which wear out easily.
I had 2 of the newer one's, they were underpowered, and the clutches would slip under load.. and yeah, the oil pump was not designed to last..
/ Just another junk chainsaw #663
Gee, Harbor Freight sells Poulan saws so they must be good......:thumbdown:
Actually Poulan Pro saws are perfectly good for most homeowners who use chainsaw for 15 - 20 minutes occasionally (No good for "Pro" users for sure).
Most problems are probably related to operator lack of interest to learn how to use and store chainsaw long term.
Old untreated fuel left sitting in the carburetor & tank etc.
That issue will affect all saws regardless of brand, if left as is unused for year or two...
Anyway, I kind of like the old saws I've had for a long time: Stihl 031AV 20", Husqvarna 162 SE 20" and Shindaiwa 360 16"
Looking into possibly buying slightly used Stihl MS310 from a family member, perhaps to replace the 031AV.
Just saying.
/ Just another junk chainsaw #664
I have a Poulan for a second saw. I bought it new for 100 bucks with a hard case. It's perfect to bounce around in the truck in rain and snow for when I need to move a tree out of the road, and if somebody did feel they needed it more than I do I'm out a lot less than one of my good saws.
The drawbacks are lack of power, no vibration dampening, and it seems like I'm constantly retuning the carb.
You just got to know which ones to buy of any brand IMHO. I just sold and traded these poulans 54cc and 2 60cc. They run and cut right with the s036 h262 etc for far less money. ;)
Mag case and all and built like the 036.
I like knowing each time I sell one used for 150 local, it keeps someone from buying a 400-500 plastic saw new in the name brand.
/ Just another junk chainsaw #666
View attachment 630054View attachment 630055
Redneck . . . I like your attitude . . .
/ Just another junk chainsaw #667
I bought a little 40 cc Craftsman saw back in 1993 and it's been pretty good & reliable as a backup saw for occasional small wood cutting around the property.
Not sure who made it, but my guess is Poulan?
As I recall the only issue over the years has been the three AV springs, which were too soft originally and were replaced with updated springs about 20 years ago!
View attachment Specs.pdf
Need to get a handle, had a bar and made up a stihl full chisel picco chain. That chain makes a big difference on the little saws IMO.
Almost ready again for owner.
/ Just another junk chainsaw #670
There must be a story behind that bent bar. :confused:
@goeduck he said he got it stuck on a drop. So he grabbed another saw and tried to finish the drop. Thats when it all went bad for him and the saw.
He brought old chain for me to check to see if I could save it. Drive links were bent bad too. So nope.
All fixed. New handle, new stihl full chisel picco chain, used bar.
One of the good ones I redid 65cc with updated tank and air filter set up. With updated coil spring AV too.
Already sold and heading to the great white north in Jan.
p415bccccccccc.jpgp415bcccccccccc.jpgp415bccccccc.jpgp415bcc.jpgp415bcccccc.jpgpp415bccc.jpgpp415bcccc.jpg
Me likey when a new customer = homeowner firewood cutter shows up with this. 2014 husky 390. He said he runs 24" most time and has a 32" too.
I threw my 24" bar and chain on it for test and tune session.
/ Just another junk chainsaw #675
View attachment 633001View attachment 633002
Smart. I have a saw that I use 25 inch and (rarely) a 32 inch bar. I had it tuned on the 25 inch.
Came in hard to start. If does start wont stay running. :thumbdown:
Less then a hour trouble shooting ready to go back. :p
Love when their easy fixes. :thumbsup:
Also notice stihl is putting china made bosch plug in some saws. No wasnt the plugs fault either. Plug still good.
Another stihl come in hard to start. Also came from factory with china made bosch in it. Bought in 2008 - after.
Issue was just bad ethanol mix jelled particles. Put my e-free mix and checked everything and back out.
Put my china g66 I been testing side by side. Couldnt tell any differences in the cut. One of the nice 660 I have seen in a long time, if grime was cleaned off. But it is a tool to be used.
/ Just another junk chainsaw #678
Yep, I like Sthil as well.
Have a nice little 009 that never lets me down, light and powerful for its size.
Last summer a tree surgeon offered to trade me even for a larger new Husky but I refused. (I also have a turbo Husky that runs just great for felling)
Lucked into a couple used 54mm cylinders and 2 NOS piston and a used one.
Time to build another 83cc. Was building 3rd 71cc in that series that is even rarer, but might switch that. PP445 PP505
/ Just another junk chainsaw #680
View attachment 640796View attachment 640797
Anytime I see a 660 around here its a nice saw. Just dont see too many of them around here. A little on the big and heavy side for the average firewood cutter in these parts. Buddy of mine has one. Good runner, but I dont like lugging around the weight.
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2022 John Deere 317G Track Loader (A63109)
2022 John Deere...
2012 International ProStar Truck, VIN # 3HSDJSJR6CN671926 (A61165)
2012 International...
2012 Volkswagen Passat Passenger Car, VIN # 1VWBH7A33CC033108 (A61165)
2012 Volkswagen...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
