Rotary Cutter Moving on up - My Rotary Cutter decision dilema
   / Moving on up - My Rotary Cutter decision dilema #31
Thanks Hozzie!
I would really like to get a 12 foot batwing cutter to decrease my mowing time.
Do you feel you could run it with less horse power?
I am also looking forward to hearing how it works when the grass is green.
I too think the high blade tip speed should increase the cut quality.
Thanks Hozzie!
Too be honest, I think it's too early to say if I think less HP would run it ok. I think it will do just fine in green grass with my tractor. It was recommended by the dealer and friend to sharpen the blades closer to a lawn mower blade and it will help with the cut as well. I will show in some more video in the final version that when I added 1 more ring to raise the height another inch or so it really helped with dispersing the clippings. I was also mowing pretty fast and will simply slow down a bit if needed. I was amazed at how much faster it makes mowing go. I think it will cut down times over half since turns take so much time and I will be turning a lot less as well. It's obviously my first use, but very happy so far. We will see how it holds up. It is built well so unless something really odd happens, I don't expect any issues.
   / Moving on up - My Rotary Cutter decision dilema #33
Looks great on the drone video! Looks like it will meet your needs just fine.
30KW GENERATOR (A58214)
30KW GENERATOR...
2006 TerraGator 8104 (A56438)
2006 TerraGator...
JOHN DEERE 470G LC EXCAVATOR (A60429)
JOHN DEERE 470G LC...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
