PT expectations?
   / PT expectations? #1
jwangelin
Member
Glenwood, NY
Bolens HT20
Hi,
Saw an ad for a PT the other day and started considering a used PT 425. Seems to be priced right with a number of attachments. This would be a 4 season tool, I have about 2 acres at the base of a hill. Mowing, snow plowing, snow blowing, and a loader for dirt and ice would be the majority of uses. I live in snow country in Western New York. Do they do well in snow? Do the decks accept recycling blades? (I hate raking) How do they do on soft ground? I have 1,000# plus Bolens that sinks into the grass in spring and fall. Would this still be an issue? I see that the dealer monopoly can be expensive. I had been considering a green or orange tractor but this would also meet my needs.
Thanks in advance,
Jon
   / PT expectations? #2
Honestly I know nothing about a PT 425. The small wheels do not look to me like they would do well in much snow. Check it out: PT425 Home Page
   / PT expectations? #3
Hi there! I can answer one of your questions about the 425 and the climate you live in. The 425 with the Robin Subaru does not start well under 35 degrees f. So PT was putting a 120V heat pad on the hydraulic tank. I did not like how long it took to heat the oil up so it would start. I hear that the 425 with the Kohler engine does start much better in cold weather.
Hopefully this info helps ya out.
Josh
   / PT expectations?
I wonder how many units they sell per year? For the number of years they have been in business I would think there would be more people talking about them although this is a product that small businesses and municipalities would use instead of homeowners.
Thanks for the mossroad link, I haven稚 seen that.
I guess it makes sense about heating the oil. One of our warehouses was I heated and the hydraulic shear struggled in mid winter till we ran a torpedo heater on it most of the day. I assume the engine is directly coupled to the hydraulic pump.
   / PT expectations? #5
Wonder if synthetic fluid would help with cold starts ?
   / PT expectations? #6
Hi,
Thanks in advance,
Jon
They are heavy and in the spring it will tear up your yard and the rear wheels on the mower deck don't help. They don't get around the greatest on steep hills. third used chains in the winter at times on the front wheels.the Robin I never had trouble with in the winter as it was in the garage and when I needed to plow I would turn the heat on early and it fired right up. The good side it is the best small machine ever saw on the bucket and it will carry a half a ton of stone with no trouble, and with a ripper I made for it there wasn't much i couldn't dig. Don't get Ag tires just get the regular ones chained work better on them and in the spring if you are careful when turning as not to tear up the grass you will be all right.. jim
   / PT expectations? #7
We don't get much snow here, but i've not had problem pushing two feet of wet snow around. The plow is on the front and can be angled left , right, tilted forward and backward and of course it's on the fel arms so up and down. I use ag tires so don't know about the regular ones. I don't really have a yard, but the rough cut desk has none swiveling rear wheels so they do dig into the wet ground when turning sharply. I got PT because the hill sides where i live made the other tractors too unstable, i.e. lifting rear tire unstable.
   / PT expectations? #8
On steep hills it isn't the stability, it is the lack of travel power if you are mowing... It is a real task to keep the front wheels down when mowing side ways on a hill it keeps riding up on the arms. They did make down pressure set up for them at one time to stop this...... jim
   / PT expectations? #9
I think you're referring to the draft control on some of the PT models. It raises the implement off the ground, which takes weight off the implement wheels, which transfers weight to the front wheels of the tractor, which increases traction on the front wheels of the tractor. I'm not familiar with HOW it works, but I'm pretty sure this is what it does.
I'm sure someone with draft control on a PT will chime it to debunk/confirm my theory. :laughing:
   / PT expectations? #10
Hi,
Thanks in advance,
Jon
First, welcome to TBN! :thumbsup:
- What year is the PT425?
- Does it have the quick attach or are the implements pinned on?
- Which engine is in it; Kohler or Robin/Subaru?
- Mine does fine in snow on my flat ground with turf tires. It crabs like crazy in snow on side hills. If I had hills, I'd get chains for the turfs and I think it would be fine.
- I have the 60" power-angle snow blade. It works great! I can stack snow 6' high.
- I have no experience with the blower, so can't help you there.
- FEL is fantastic for such a small machine. Buckets, forks, snow plow, 60" finish mower, 48" brush cutter, a 2" receiver attachment. Be aware of the lift height, though. It will not load a pickup truck from the side. I have an 18' car hauler trailer, and I can load that just fine from the sides over 12" side boards, so it's not an issue for me.
- My mower deck has very small spindle bolts, so it may be hard to find mulching blades to fit. Also, since it's a rear-discharge mower, the entire back is open. Recycling blades work best on closed decks, because they supposedly keep the clippings up in the air longer, getting cut into smaller bits as they try and fall. With the open rear on the PT decks, I don't think recycling blades would do that much different from regular blades, but I could be mistaken. If it's any consolation, I rarely bag my clippings, only if I need some for the garden. Then I pull a lawn sweeper behind me to gather them. The PT mower does a fine job for me. It's not like a Simplicity or Ventrac in the quality of cut, but I find it very acceptable. We don't have a "show lawn" like some neighborhoods. ;)
- On soft ground, the PT itself does fine. The front tires on the 60" mower deck are pneumatic. I tubed mine so I could lower the air pressure and not keep popping them off the rims. The rear wheels on the 60" mower deck are OK, however, if you turn tightly on soft ground, since they don't caster like the fronts, they will tear the lawn. The are hard plastic, so there's no way to air them down.
- My PT425 with me on it is right around 1500#. The weight is distributed pretty evenly. The 4 tires are all the same size. I've never had an issue sinking into the grass. However, my soil is mostly sand and sandy loam, which drains pretty quickly. I've taken it into some wet spots at the little league park and never sank it. But only you can be the judge of that. @ 1500# total, there's 325# on each tire. The tire patch with my tires is about 2X the area of my size 13 shoes with the air pressure down to about 8-9psi. So I'm making a wild *** scientific guess that me standing on 1 foot is 215#. I do know for a fact that If I don't sink in walking an area, I won't sink in driving my PT425. So you might be able to use that for a comparison.
Those are my experiences. Hope that helps.
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
