MYSTERY PTO- Mid-Mount
/ MYSTERY PTO- Mid-Mount #1
edinottawa
Ottawa, Ontario, Canada
Massey MF14, MF16, 1650, GC2300, Kubota B6000E, Kubota B6000DT
Gentle readers; I have this mid-mount PTO attachment but do not know what tractor this fits. Most likely compact / utility tractor in the 20-30HP range. Dimensions are shaft 40.5" tip to tip. Hanger bracket is 14" wide. 15 spline. Any help is welcomed. Thanks!
/ MYSTERY PTO- Mid-Mount #2
G'day Mate and welcome to TBN from Downunder.
I'll be following this thread as I can't figure out how it would attach to a mid-mount PTO... the thing that came to mind was it's a 'wheel PTO' extension to an older type, static/stationary baler or similar implement/machine.
Enjoy the site.
/ MYSTERY PTO- Mid-Mount #3
Looks like a shaft and front mount bracket to carry the mid-PTO forward for a front broom or snowblower possibly.
Thanks for the comments so far. I did drop into a local tractor dealer that has a very large repair department. The ancient mechs were not able to point me to a brand name. They did say its a mid-mount PTO for front-mounted attachments (snowblower, broom, mower, stump grinder etc.). They also told me the bit about 20-30HP maximum due to the guage of the metal and shaft.
/ MYSTERY PTO- Mid-Mount #6
OK, that makes sense...
I just did an image-search for 'mid mount pto' to see that the PTO faces forward, so I can now see how this would work.
I've learnt something. It's a good day. :thumbsup:
/ MYSTERY PTO- Mid-Mount #7
Yes.. It is obviously a front tractor side mount to carry the pto.. Then the implement mount and lift system would attach to this bracket, with a short pto to the implement.
It does not appear to be anything that I have seen used on John Deere compacts. I have seen a number of mounts, but not all I'm sure.
Good luck.
Hi Aaron; the only number is a standard Neapco U-Joint part #. Nothing that leads me to the manufacturer of the rest of it. The stamped frame has no markings at all.
/ MYSTERY PTO- Mid-Mount #9
Looks like it would fit the front of my GC1700 series Massey, it is a clean almost universal looking mount for mid to front pto, if it fits it will work type deal with the exception being the length of the pto shaft.
I think I would need to flip it so the off set is on the left rather the right while sitting on the tractor but maybe it would not matter and like I said it looks universal.
Woodland Mills Sawmill (A65579)
Woodland Mills...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
96"X18' TRI-AXLE TRAILER (A64280)
96"X18' TRI-AXLE...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
