Oil & Fuel Cool weather performance.
/ Cool weather performance. #1
Ohio RK24
2019 RK24
I went out to do some work today and started my RK24 as normal Glow plug then start, normaly it is pretty smooth while warming up but today it shook and rattled as though it were going to come apart and would not respond to throttle, after thereto five minutes it smoothed out and acted as normal.
weather was sunny about 62 degrees fuel has Howes diesel treat additive mixed for summer, my question is wether this is normal or not.
/ Cool weather performance. #2
I know what you're talking about, rattle and shaking. Especially now that the weather is cooler. Find some Cetane boost and you will notice a big difference if you increase the Cetane in your diesel fuel. Aim for 8 points increase. I use AMSOIL Cetane boost and was totally impressed with the first tank that I mixed it in. Way way less rattle on cold start up. AMSOIL Diesel Cetane Boost.
Dutchy
Very much appreciated, being new to tractor ownership I am learning as I go and folks like yourself help a great deal. I will look into the cetane booster you recommended.
2002 Freightliner FL112 S/A Day Cab Truck Tractor (A61568)
2002 Freightliner...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
New/Unused 2 Post Car Lift (A61166)
New/Unused 2 Post...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED SDLANCH REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED SDLANCH...
