Backhoe TLB trenching on steep hill
/ TLB trenching on steep hill #1
PA452
PA
Kubota B2650
I'm going to have to dig a trench for a pipe on a somewhat steep hill soon. Trench will be generally with the hill, not cut across it. Given the option, would you prefer to dig with the tractor on the uphill side or the downhill side?
/ TLB trenching on steep hill #3
Tractor on downhill side. Starting from the top obviously. If you take a bite with the BH and the tractor moves, it moves uphill slowly against gravity; much easier to recover. If you tried to dig with the tractor ABOVE where you were digging, you may quickly find yourself IN the trench or worse, rolling @$$ over tea-kettle to the bottom.
/ TLB trenching on steep hill #4
Yep, always dig downhill. It resists sliding and you have more capability to level the tractor using the FEL than you do with the stabilizers. I have dug horizontal on a slope in my yard for sprinkler piping that required the downhill stab to be fully extended and the uphill just firmly touching. Not fun but doable.
/ TLB trenching on steep hill #5
Have you considered renting a 4 foot trencher? I own a backhoe but opted to rent a trencher and it was a far better option and way more efficient since it only digs out a narrow trench continuously and dumps the dirt on one side. Trench, lay pipe, push the dirt back in while tamping as you go. Clean & quick.
/ TLB trenching on steep hill #6
Unless it’s upwards of a couple hundred feet I’d be done with the backhoe before you ever got to the rental place and back.
Thanks guys. Top to bottom was my gut feeling as well, just made sense to me. Then someone said I should really dig bottom to top, which I disagreed with but figured it was worth throwing it out there.
Not worth it. It's only about 75' (not factoring in elevation). These sorts of jobs are why I got the backhoe. :)
/ TLB trenching on steep hill #9
+1 QFT
/ TLB trenching on steep hill #10
Agreed. There are circumstances where it’s wise to rent equipment when you already own something but this isn’t that time.
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A61307)
2023 Top Air ATV...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2019 Bobcat T870 (A60462)
2019 Bobcat T870...
207271 (A52708)
207271 (A52708)
ATTENTION PLEASE READ (A60462)
ATTENTION PLEASE...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
