Brush removal project -tree puller attachment?
/ Brush removal project -tree puller attachment? #1
Hay Dude
Epic Contributor
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
I bid on and was awarded a decent size brush removal project. It's not an ordinary project, though.
What makes it a little different is the brush is located along about 800' of stream and a 200' long pond in swaths about 10-20' deep. The brush was allowed to flourish along the pond and stream for 5+ years while I farmed hay just beyond the brush.
The property is very delicate. It's a historical farm and is a National Historic Landmark site. The project is very visible and "neatness" counts big time. I cannot go wild with a skid loader and brush cutter and make a big mess.
The brush consists of many autumn olive trees, mostly 2-3" in diameter and many other species of stickers and invasive brush.
The ground is semi-damp. Customer (a local land conservancy) wants me to wait until winter to reduce ground compaction and disruption of animal species. Their hope is the ground may be frozen. That's about a 50-50 chance.
I have 3 farm tractors, 2 with loaders and hydraulic circuits out at loader ends.
I was thinking of approaching the stream/pond perpendicularly with tractor/loader and grasping the olive trees and "plucking" them out of the ground with a "tree puller", then cutting the rest with brush cutter & saw blade, keeping tire ruts to a minimum.
I also have a 15' Deere CX-15 bush hog, but it may not be able to be utilized in many places along the stream and it will throw a lot of flying debris into the pond.
I would have to invest ~$1,500 in the tree puller.
I welcome any suggestions and one question I have is the tree puller really effective? Would it also grasp brush and pull it, or would the brush "slip through" the jaws?
/ Brush removal project -tree puller attachment? #2
I’ve got a decent amount of experience with a Danuser puller in front of a 95-2 Kubota CTL. It’s a mean machine and would do a neat job. But it’s $3,000 and I think it would be close to useless on a tractor. Cutting the brush with weed wacker blades is the worst of pretty much any option. You can’t mow over it for all the tire popping stobs and they’ll grow back quick.
Thanks for the reply. Why would a puller be useless on a tractor?
/ Brush removal project -tree puller attachment? #4
Because you don’t have nearly indestructible loader arms, 7500 pounds breakout force or anything close to as good visibility.
/ Brush removal project -tree puller attachment? #5
Do they want you to just cut it or remove it?
Not sure about your specific situation, and I can only speak about the tools in my shed, so on that note, I use my 3 point hitch skidding winch to remove a lot of trees, bushes, and brush, ....from remote distances too. Handy for not ripping/rutting up where you don't want things rutted up.
Just a few weeks ago we wanted to remove four bushes from in front of my apartments but I didn't want to drive on lawn. Took 4 choker chains, wrapped one around each bush, and with one pull gone, roots and all, while tractor stayed parked on driveway. Granted, this is different than a 1000' x (10'-20')' area, but have used same technique and one big chain with a slip hook around clusters of bushes.
/ Brush removal project -tree puller attachment? #6
I don稚 think a puller is a good idea on a tractor unless you have a giant 100+ HP class ag tractor. You need the low center and power of either a large commercial loader or a track steer. You risk twisting up your loader arms. Look at people on YouTube trying to use a stump bucket on smaller tractors, it痴 too much strain on them IMO. A stump bucket on a track steer is another way to do it too. Use a grapple on a tractor to pick them up while someone uproots them with the skid.
A mini ex with a small bucket and thumb would do the job well too. Use the tractor to level it all out and clean up after.
/ Brush removal project -tree puller attachment? #7
I have a Brush Grubber purchased from Northern Tool for about $80 and I'm very happy with it. I use it to pull 1" to 3" trees with 10' or 20' of 5/16" chain hooked to either the drawbar or the FEL, depending on the terrain and situation. The tractor is a Kubota B2320. They sell larger sizes that might suit your project for a lot less than $1500. It makes a world of difference if someone is on the ground hooking the tree and someone else is on the tractor. Hooking, unhooking and moving the chain takes a few minutes per pull.
/ Brush removal project -tree puller attachment? #8
How do you plan to smooth the land back out after removing the trees? There will be holes and rough ground after the roots are pulled out of the ground.
/ Brush removal project -tree puller attachment? #9
Is chemical removal out of the question? Spray, wait a year, and shred...minimal impact.
/ Brush removal project -tree puller attachment? #10
Personally, I think I would have had all this worked out before bidding the job.
/ Brush removal project -tree puller attachment? #11
I've pulled a lot of brush over the last 5 years. Never a "neat" process. If you want the cleanest way, then cut the larger stuff , small tress whatever, off right at the ground with a chainsaw and leave the stump in the ground. Spray the top of all the stumps with roundup after, and it will make them die and rot much quicker. Then weed whack and rake the rest. If you try to pull stumps out, it is very messy either way you do it. If you try to do it when the ground is frozen, it makes it harder to pull them out because now the roots are frozen into the dirt, and you also remove more dirt. Your tractor can probably do it, but you will find the trees break before the stumps come out.
What about a controlled burn?
/ Brush removal project -tree puller attachment? #12
Unless you way overbid. If talking about buying a $1500 puller, then has some room there I would guess.
/ Brush removal project -tree puller attachment? #13
Getting the job and then figuring out how to do it is just part of running a small business.
/ Brush removal project -tree puller attachment? #14
I have the MTL puller ($1000). I have three issues with it. First is that my FEL/tractor cannot pull trees out unless I rock them back and forth a bit. Second, the jaw has enough force to cut a small tree less than 3" in half. Lastly, it is impossible to see what I am doing.
The last issue is being addressed. I installed a camera yesterday on the front so I can see want I am doing. With the camera, I intend to plunge the jaws just below ground level and shear the tree off instead of pulling it out. I expect trees under 3-4" can be sheared off above the root ball. Trees over 4" I am hoping to use the shearing action on the roots and then pull the tree out by the trunk. I have thought about grinding a bevel and shearing everything but it is a lot of grinding.
/ Brush removal project -tree puller attachment? #15
I had a big autumn olive patch on my property. I got someone with an excavator to take care of it when the ground was frozen. The trunks would tend to snap off at ground level in the frozen earth. He dragged the bucket of his excavator across the patch a few inches above ground level and gathered them up, it was almost like combing. There was very little earth disturbance, the excavator didn't even make tracks in the frozen ground and the trunks snapped pretty cleanly. We piled the brush and burned it and instituted regular mowing and the land is hayfield now.
My experience with the tractor is that frozen ground gives the best traction of the year for pulling stuff out.
/ Brush removal project -tree puller attachment? #16
I would not bring my tractor anywhere near those trees. You're going to make a complete mess out of that ground and possibly worse, get your machine stuck in the process. I pulled out hundreds of trees with my ASV/Terex track loader with a tree-puller on the front.
In my opinion you will want to be renting a tracked machine for this job. The ASV/Terex units are unique amongst track loaders, their suspension handles soft ground conditions much better than any other system on the market. I have used most of the others, they all have their strengths and weaknesses, in this case this is a major strength for the ASV units.
I figured a 135hp farm tractor with loader would have plenty of breakout force to uproot small trees like autumn olive. They have pretty weak root systems.
/ Brush removal project -tree puller attachment? #18
It's not the power, it's the working conditions. I'm sure your machine would have the strength to pull them out, but you describe the area as fairly wet. Not a great place for a wheeled machine to play in.
I do have it worked out, but by chainsaw, brushcutter and chipper. I was merely asking for any advice on buying a tree puller as an aid to the task.
I've been farming and clearing land that's been turned to hay fields for 30 years.
The only difference is the stream and pond does not allow the same manuverability as an open field, so looking to assemble the optimal tool/equipment list for this particular task.
It'll be frozen this winter.
4004SFL (A59228)
4004SFL (A59228)
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
2021 Ford Econoline Van, VIN # 1FDWE3FN3MDC22817 (A61165)
2021 Ford...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2017 Nissan Quest Van (A61569)
2017 Nissan Quest...
2014 FREIGHTLINER  CASCADIA (A60736)
2014 FREIGHTLINER...
