Looking at pull type snowblowers
/ Looking at pull type snowblowers #81
I agree on that video. Hardly considered a snow event. Inverted have their place in some situations with light non drifted snow, even a couple of feet. Here on the on the prairies the snow will drift three feet high across the road and you can drive up onto the drift. This situation requires a push type blower, be rear or front mount. Just a different perspective for those who've never experienced a prairie blizzard. The tractor goes in the shed with the blower facing out, ready for action.
/ Looking at pull type snowblowers #82
Happens here as well with roads going through farm land, nothing stops the wind.. My brother has 8ft drifts in his driveway.. He uses an 8 1/2 foot Lucknow and pushes it with a Ford 7710 and a Cat backhoe 4x4 to move banks..
/ Looking at pull type snowblowers #83
Huh? Just change the direction of the spout or adjust the deflection chute!
If you watch the video buddy is blowing all the snow up hill and onto the house...buddy must like ice dams and wet basements...or maybe the guy in the video is a contractor and his summer job is wet basement repairs.
/ Looking at pull type snowblowers #84
The only way to use one of those is to either chain up all four tires and keep up with a storm or put it on a big tractor.. The snow depth in that video is nothing, if I had one of those on that size tractor and waited until one of our average 2ft storms was over I would be stuck in a hurry..
What do you mean? 2 ft snow is nothing?
/ Looking at pull type snowblowers #85
I live upstate NY where we get plenty of snow. When I bought my used L3540, I got an old school 6’, single stage pull behind snow blower for 250 bucks. It needed some tlc but works great. I sometimes wish for more hp (which the OP has) when it’s deep (15-18”) but works great on my 750’ blacktop driveway and it’s. I’ve never had an issue with driving over it first, and find that having the loader on all winter is very beneficial.
However, I think you said that you wanted to go even wider, and I might caution against that. I’d think an 6’ would be perfect for you as it still should cover the width of your tracks. I’ll try and find a picture or two.
/ Looking at pull type snowblowers #86
/ Looking at pull type snowblowers #87
In that video by the looks of how much snow he was driving through, looked to be 6-8 inches, if he tried that in 2ft of wet snow or snow on top of ice he would be struck in a hurry.. That's what I meant..
/ Looking at pull type snowblowers #88
I assumed that if you were on the tractor, you would be bright enough to change the direction of the spout or adjust the deflection chute!
/ Looking at pull type snowblowers #89
Not the first time I have seen people brake windows in their house because they didn't change the deflection chute direction.. It was probably his first video and wasn't paying attention..
/ Looking at pull type snowblowers #90
We do the same here in Lake Superior's peak snowbelt. An overnight snowfall of 18-24" with drifts of 3-5' happens a few times each winter. Whether front or back mounted, the blower has to clear the tractor's travel or else you'll be stuck immediately.
/ Looking at pull type snowblowers #91
I would venture to say a pull type blower would work in areas that get light snowfalls if it's hooked to a big tractor, If it has a sharp cutting edge it might scrape up the snow that you already drove over, if they worked well in deep snow I would see them everywhere here in ME, I have never seen one, the idea of driving over snow pulling a blower makes no sense to me..
I have moved snow about every way possible, trying not to get stuck and pulling a blower over packed snow isn't one of them..
/ Looking at pull type snowblowers #92
I don't have a pull type blower, but I do plow a lot of snow with my pull type back blade.
I have no problem pulling that through more then 18" of snow.
/ Looking at pull type snowblowers #95
Excellent videos, thank you for sharing. I visited Scandinavia last year, Oslo, Stockholm, and Copenhagen. I see you are from Norway. I was so thoroughly impressed with everything I saw in these places! I tell everyone who will listen that they must visit. Its so clean, happy, and healthy. Gorgeous all around!
If I had a tractor that large I would not be so worried about getting a rear inverted snowblower. But I have an L6060 and am worried that for some reason my 2 steep asphalt hills (15% grade) will be a nightmare.
/ Looking at pull type snowblowers #96
All those small tractors are falling for the very bad idea that tractors should pull and not push at the rear, it would not cost much to have a dual command so you could turn your seat and have rear controlls so you could push without killing your neck, Valtra has this as an option and as you can see on the last video it makes blowing with a rear blower a pure pleasure.
/ Looking at pull type snowblowers #97
Thanks, we have it alright, I must admit that.
/ Looking at pull type snowblowers #99
Both videos tell the story.. Both big tractors, the pull type blower is working in a light snowfall, the push blower is working in the deep stuff, pretty simple math there..
/ Looking at pull type snowblowers #100
If we are talking real snow and drift then tractors are a joke, to little power and you can't lift the blower to take the snow in steps.
Rear pull blowers works fine, but you can always find situations where they are not ideal.
2016 Ford F-250 Service Truck (A61568)
2016 Ford F-250...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2016 Chevrolet Silverado1500 Pickup Truck, VIN # 1GCRCNEH4GZ236800 (A61165)
2016 Chevrolet...
UNUSED CFG INDUSTRIAL MX12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
2023 John Deere Z950R Zero Turn (A63116)
2023 John Deere...
Knapheide Service Bed (A61165)
Knapheide Service...
