Rounded off drain plug
/ Rounded off drain plug #2,001
You can buy new style drain plugs that are actually a little spigot, similar to drain plugs on air compressors or car radiators. But if youre wanting to keep that factory FD unit, you can weld a little T-bar on it or a nut on top of it to renew its youth.
/ Rounded off drain plug #2,002
For years, I've heard that water swirls in opposite directions in the two hemispheres. Recently, someone said that was incorrect. I've never paid enough attention to know which way it swirls anyway.
Ive always wondered why, when we look in the mirror, the left side is on the right side and the right side is on the left side.... BUT the top is not at the bottom or the bottom at the top?
/ Rounded off drain plug #2,003
Doors are similarly very confusing. When you go in, the doorknob is on the left side. When you go out, the doorknob is now on the right side.
Bruce
/ Rounded off drain plug #2,004
Because our eyes are located side by side? :D
/ Rounded off drain plug #2,005
My right side is on my right side in the mirror image and my left side in on my left side in the mirror image. What kind of mirror do you have?
:shocked:
/ Rounded off drain plug #2,006
:shocked:
Hold your right arm out and turn around, it will be opposite what you saw in the mirror...lol
think of shaking hands... the mirror is a lefty..lol
/ Rounded off drain plug #2,007
It is still on the correct side. Besides, who on TBN turns around and looks in the mirror? :hypnodisk:
I mean, who needs to look at old mans but?
/ Rounded off drain plug #2,008
/ Rounded off drain plug #2,009
Bruce
To determine whether a door is a right or left hand door (swing)...stand with your back to the hinged side of the door...if it swings to the right it's a "right hand door"...if it swings to the left it's a "left hand door"...it does not matter from what side you address it...
/ Rounded off drain plug #2,010
Wow 2200 comments on a rounded off drain plug. Obviously a lot of posters have way too much free time.
Simple solution for a rounded off drain plug, buy a cheap socket the fits over the buggered hex and wire weld it on. No more buggered hex.
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2017 Ford F-250 (A55973)
2017 Ford F-250...
2018 ADDCO ROAD SIGN DH1000-ALS (A60736)
2018 ADDCO ROAD...
(1) Camso 15-19.5 Foam Filled Tire (A60463)
(1) Camso 15-19.5...
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
KJ K4525 45'x25' Double Garage Barn Shed (A60463)
KJ K4525 45'x25'...
