Rear Quick Hitch Dimension and Clearance
   / Rear Quick Hitch Dimension and Clearance #1
Stussy1035
John Deere 1025R, Craftsman 1994 GT6000
I currently do not have a category 1 quick hitch put plan on buying one in the next few years. I was interested in making a few rear implements and would like to know what is the typical dimension between the center pin and the bottom of the frame member of a quick hitch to make sure I have enough clearance. I understand different brands have slightly different designs and looking for a rough estimate of this dimension. This would be greatly appreciated.
Can you please provide the the following of the category 1 quick hitch. If manufacture or model is not known, then dimension only will be ok.
Category 1 Hitch:
Manufacture
Model
Red Dimension as shown in the drawing. From center of pin to under of frame member.
   / Rear Quick Hitch Dimension and Clearance #2
These should have all that is needed.
Bruce
Hitch dimensions
Implement dimensions
That is perfect, and even has more information that I currently need. I did not know that document exists. Thanks.
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
1453 (A57192)
1453 (A57192)
