Lean to Shed
/ Lean to Shed
So in these very basic, and not to scale, drawings you can see the lean to shed from one plane. The length or depth of the shed is dependent on the height because of the roof overhang that i'm working with. The taller the shed is the narrower the roof line is. I don't want to go any less than 24 ft long/deep. Obviouisly I can go shorter and gain more length. But is 9ft tall with a 2/12 pitch and 5'5" at the post end TOO short?
Also the span tables confuse me. I will be using southern pine on this project. And if possible would like to run the rafters unsupported from house to the post. If need be I can put another post, or set of posts, down the center of the shed to support the rafters.
Please advise.
Like I said, the span tables are like greek to me.
/ Lean to Shed #22
Don’t know if this helps or hinders. This spring I extended my tractorshed 22ft. Used 2x6s @ 16 inches OC. Might have gone with 2x8s if longer. My mid support break is 6/16 as I couldn’t put in middle. Need the width to make the turn with mower on. Not much slope due to starting point, but no snow load and not a problem with the rain. (140 in/yr our norm)
/ Lean to Shed
Also looks like you did very little cutting of boards. No birds mouth. All brackets?
/ Lean to Shed #24
View attachment 617687View attachment 617688
Please advise.
It all depends on your use and what you can deal with. I wouldn't go less than 6 feet on any wall because I would end up hitting my head on the rafters eventually. If I wanted to get my tractor in with the ROPS up, I would need 8 feet minimum. Your choice.
Take a look at the span tables again. It's not so complex. You can pick a table with the lowest loading and highest deflection because you don't deal with snow and I'm assuming you will have a light roof like metal. The tables usually have the rafter spacing (12", 16", 24" etc.) on the vertical column and the grade of lumber on the horizontal. The body of the table shows span. Looking at southernpine.com, and the lightest rafter table (20 psi live load, 10 psi dead load, deflection limit l/180) I find that you can span 19 feet with 2x8 on 16 inch centers with No. 1 lumber. Because I know the tables are conservative and we are talking about a shed, I wouldn't worry about 19 feet vs 20 feet and I might go ahead and stretch it to 24 inch centers. The other option, of course, is to go with manufactured half trusses. Then you could go to 4 foot or 8 foot spacing.
It's your decision.
/ Lean to Shed #25
Keep height in mind if you are pulling the tractor in. I lost a friend several years ago when he was pinned between the building and the ROPS. No one else around so we do not know exactly what happened, just that he is no longer with us. I've been much more attentive to heights of solid objects since then.
/ Lean to Shed #26
Please advise.
No way I would go less than 8ft at your shortest unless something is dictating this. 8ft is a standard board length so no cutting (least waste) and you can 'lean' most anything against it. I'm 6ft +. I sure don't want a roof lower than the top of my head, or ROPS, or other stuff. Go 8ft if you can!!!
/ Lean to Shed #27
Right and the tractorshed ends rest on that header and nailed to existing rafters.
/ Lean to Shed #28
As you can tell from my previous pic, my tractorshed grew overtime, not something well planned leading to what it became. The far left started as an open lean to and grew over time with the roof extending down to a 7ft height. Not a big problem, meant for mowers and implements. Eventually it became walled, then garage doors added. Think I ended up with 6’3” doors. Not a problem for my 5ft wife, but she often doesn’t open fully so I have bumped. Do have to be mindful when moving stuff.
2nd the 8ft min if possible.
/ Lean to Shed #29
... But is 9ft tall with a 2/12 pitch and 5'5" at the post end TOO short?...
5 1/2 feet is up to you on your height. There is no rule on how tall a wall has to be for a lean to, it's just a question of how often you will hit your head when you are in that area?
The other question is if your measurements are for clearance under your rafters or to the top of your rafters?
Here is an easy to read span table that gives you 20 pounds live load, which is pretty good. You will have to use 2x10's to go 20 feet. The table says that if you use number 2 southern pine, which is very common, you have to space your rafters 16 inches.
Rafter Span Tables
If you use 2x8's every 12 inches, you might have some sag in that roof eventually. 2x6's should not even be considered for this much span. In my mind, the small additional cost of the proper sized lumber will be cheaper in the long run when you never have to deal with any issues in the future.
One of my common jobs here is dealing with what people think are foundation issues. But in almost every house that I've looked at, it's attic issues. Especially open concept homes where they saved a buck going with lumber that was too small. This allows the house to move more and causes cracks in the sheetrock and trim. Sometimes it's been rather severe, and in those cases, the lumber was way off on what they should have used. It costs thousands of dollars to fix some of these homes when it would have cost a hundred bucks more when they built the house to do it with the correct sized lumber for the spans.
/ Lean to Shed
So if I use my taller Design i can actually extend it out further to 24'. With exterior wall around 7 ft 4in. Yea that's at the roof. I'm thinking a 2 12ft openings (minus post widths will be better. The rafter runs could be in 2 separate boards. One from the house to the midway post and another from the midway post out to the exterior wall. Would running 2 Boards for one rafter make sense? How would you join the 2 together? Bracket them to the midway post? Also for the header board on the existing house if it were to be 24 ft long along the house would I just double up boards and stagger the seams between boards? 16 and
ft and 8 ft from left ro right for first layer and 8ft and 16 ft from left to right for second layer? What size board for header ledger and run between the midway posts?
/ Lean to Shed #31
Why are you building a lean to instead of extending the existing rooflin?, or if that's too big, build a new roof that matches the existing roofline below the existing roof?
/ Lean to Shed #32
$$$ and ease of project, I imagine... I am wrestling with an extension to my garage vs. a lean to. But a real good question!
/ Lean to Shed #33
For something that you have to live with and could add significant value to your home, it's not a lot more money. Especially when you end up with a space that has 8 foot walls or taller all around it!!!
/ Lean to Shed #34
Maybe an actual pic of what you are working with?
/ Lean to Shed
I'm sorry. I thought I had posted this picture. The roof runs perpendicular to the side of the house that I'm working with. Cost and ease and installment is the biggest reason. Also structure is sound level. It will remain as it is for the foreseeable futureIMG-20190803-WA0001.jpg
/ Lean to Shed #36
On our property we have an old house that had a fire in a portion of it. The house is unusable and will eventually be torn down. I am looking for some additional covered storage out there. I was planning to put a lean to on one side of it. I am new to this type of building but am good with my hands and love to learn.
Do you have power to the building? That weather-head should be raised, but if you leave it where it is, that is going to severely limit what you can do off of this side of the building.
Looking at the picture, and re reading what you originally posted about the condition of the building, and they need for storage, I'm wondering if you could just remove the two windows and open up their opening big enough to turn that part of the house into your storage area? Dollar wise, it would be cheaper then any other idea that I can think of. You can get 9 foot wide garage doors from Lowes pretty cheap if you wanted to close it up, or just leave it open like you would the lean to idea. How bad is the roof? Can you cover it with metal like you would the lean to? Put the money you are going to spend on the lean to and create a barn/garage out of the house?
/ Lean to Shed #37
I’m building a leanto also. The span from wall to inside of the posts is 14’ 1”.
I have 2 x 10s for the outer header.
Sodamo, would you feel comfortable using 2x6s for my span? Torn between using the 2x6s and 2x8s. IMG_0800.jpg
/ Lean to Shed
Eddie. The picture is a little dated. Power is no longer running to the house. And that weatherhead and everything else on the side of the house will be removed. The roof is an excellent condition. The house previously had an interior fire that has interior fairly damage but the bones are still in tact. I do not know if it would be wise to Park anything heavy on the floor. There is a crawl space Under the house.
/ Lean to Shed #39
Now that all of the electrical stuff is out of the way, cut a big hole from window to window and put a header up!!!!
Why keep the floor? Cut it out too.
Since your walls are resting on the floor, you need to cut it out a little at a time so you can make sure the walls on the joists dont move, but a little bracing should solve that.
Use what you have already standing there and forget about building a half *** lean to.
/ Lean to Shed #40
Sodamo, would you feel comfortable using 2x6s for my span? Torn between using the 2x6s and 2x8s. View attachment 617950
You have to eval in entirety, but I’d likely do the 2x6 @16oc. I rarely do 24 and never 48.
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2013 International DuraStar 4300 S/A Dump Truck (A66736)
2013 International...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2011 MERTZ BLENDER TRAILER (A67714)
2011 MERTZ BLENDER...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
