Lug Nuts
/ Lug Nuts #1
woody
Central Alabama
Kubota B26, Kubota ZG222, Kubota L45, 1980 Ford 1700
This has probably been talked about before, we are getting ready for a trip so I had my truck serviced which included tire rotation after driving back and forth to work for a week I decided to torque the lugs on the truck and found each wheel had at least one and one wheel had two lugs that were not torqued enough so I moved on to the trailer that I will be pulling and found one lug per wheel moved at least a half a turn each. so friends when you get a chance check your lugs.
/ Lug Nuts #3
for sure. NSTSA has a promo running on the radio but I can't find a link to it. Humorous but it gets the point across. Long story short there's this gravelly voiced guy in the background who's a vehicle inspector and he's saying, "check your nuts....or I will" end of the commercial ..."......I'm waaiiitiing".................Mike
/ Lug Nuts #4
I pull a 5th wheel frequently, along with a couple of different utility trailers, so I used to spend some time torquing lug nuts. I finally got a good set of torque sticks for my battery powered impact driver.
Now I just grab the appropriate torque stick (each vehicle specification is written on tape inside the box) the torque wrench and socket, just do a quick walk around, then put everything back.
One of the flip type sockets works for the 5th wheel and both trailers, the truck uses a larger 23mm socket.
The other end of the spectrum is when I have tires mounted. Usually around here, they torque them down as tight as their driver can get them, way over spec, so I always check the torque when I have tire work done, that way I know if they're too loose or too tight.
/ Lug Nuts #5
What brand did you get?
I seen a set from Neiko on Amazon for $50 but I have no idea if they are top of the line or junk.
https://www.amazon.com/Neiko-02450A-Limiting-Extension-5-Piece/dp/B000IX3BSM?th=1
/ Lug Nuts #6
I got the Ares 70367 - checked them out when I got them against a good torque wrench and they were spot on
/ Lug Nuts #7
You are absolutely correct, most tire places just use air impacts to tighten to max torque.
The only place I have seen torque wrenches used was at Sam's club. They have policy that the technician tightens to spec. He uses an impact to snug the nuts, then a torque wrench to finish tightening to spec. Then he has to have a second technician verify the torque before he can release the vehicle. I couldn't believe the procedure when I bought my tires there, but it is a great process and pretty much guarantees that there will be no loose nuts.
/ Lug Nuts #8
I keep a cheater bar in my truck because it is the only way to loosen the nuts a lot of the time. I managed to bend my tire iron and the nuts still wouldn't budge. The extra leverage of a 5 foot pipe over the handle of the tire iron will break it free, plus the tire iron doesn't bend with the pipe over it.
/ Lug Nuts #9
Just had my dually tires rotated at a new garage. Just for the fun of it when I got home, I loosened one lug nut to see how tight they were. Holy crappola, were they on tight. They just popped when they loosened up. Never saw them that tight. I put a breaker bar in my truck in case of a flat. On a positive note, they won't vibrate loose.
/ Lug Nuts #10
Not really true, if the threads are stretched and deformed they lose their clamping force, not to mention if the wheels are damaged also.....Mike
/ Lug Nuts #11
Around here, the tire shops state on their invoices that wheel nuts are to be re-torqued after 100 km (60 miles). I learned about torquing lug nuts years ago when I owned and operated heavy trucks. I had a repair shop (not a tire shop) install dual 24.5" Unimount (hub pilot) wheels on one of my trucks. After about 500 miles, the driver called to say that he heard what he thought to be rifle shot. On checking, he found that one of the studs had sheared off and, of course, the nut was missing. He dropped the trailer and limped to a repair shop about 2 miles away. They found the other 9 lug nuts to be loose and the studs damaged. We replaced all 10 studs. That's when I went out and bought a 3/4" drive torque wrench, and from then on I personally checked the lug nut torque on my trucks and did the re-torque. When I was driving, I carried the torque wrench with me. And yes, over-torquing can be just as dangerous as under-torquing.
/ Lug Nuts #12
On my Massey (no torque wrench used) I must not have eaten my Wheaties last year when I replaced my front left after a flat. I lost some lug bolts while mowing a pasture. Thump, thump, thump.... oh carp. :shocked:
The replacement lug bolts are tight now :thumbsup:
/ Lug Nuts #13
A couple years ago my mechanic, me, rotated my dually tires. Air wrenched them. Looks good enough. A couple months later pulling my 15k camper a hundred miles on the interstate we exited for a few miles heading to the campground. I noticed when going across a long bridge something squeaking like gravel between the wheels if it could get picked up in there. But I figured it was the semi next to us making all the racket. When he turned off the noise persisted. Two miles later we pulled into the campground and even going slow on a gravel road the squeaking was noticeable.
Finally I parked on the road and found a screwdriver so I could get my wheel liner covers off and then I noticed that every nut was backed off by 1/2 to 3/4 of the way off. The liner cover must have held the nuts from spinning off. I tightened them up, drove ahead a few feet and re-tightened them up and repeated half a dozen times. No wear on the threads and nothing dinged up. I really dodged the bullet on this one as I usually cruise 72-75 MPH. The squeaking I mentioned before was from the very loose wheel liners rubbing across the stud threads.
PS. I fired my mechanic.
/ Lug Nuts #14
The garage I use had a new guy who put tires on my kids car. He told me I'd need brakes soon, so I got a set of pads to put on myself. When I started loosening the lug nuts to pull the wheels, I broke 3 wheel studs (on different wheels) because they were run up so tight.
That guy didn't last long at the garage.
/ Lug Nuts #15
I've noticed this twice with my wife's SUV after service with tire rotation. Noticed because of vibration in the steering wheel and a slight noise when front lug nuts not tightened and just noise when rear not tightened. Why can't service folks take the time to double check any time the wheels are taken off?
/ Lug Nuts #16
When I worked at a tire retail store, installers over torqued lugs and lit patch glue ablaze despite repeated lectures to stop. One of our flat repair customers blew a tire, lost control and struck another car. Me,other employees and patch mfgr's rep were the best witnesses plaintiff's lawyer had against the shop. Shop owner was financially ruined and I believe if it had been allowed,he might have got the electric chair for his appearant disregard and negligence. Installers weren't even scolded for their part.
/ Lug Nuts #17
Parked next to this at the grocery store today and thought of this thread. Someone did not tighten down that one lugnut.
/ Lug Nuts #19
I understand that lug nuts have to be tight. But 140 pounds? What has changed that now requires such high torque numbers?
One problem that I've encountered was having a flat tire out on the road. There was no way in the world of breaking the lug nuts loose with the little lug wrench that came with my pickup. Heck - I even had a 4-way also, and all it did was twist the 4-way. Makes me wonder - is 100# torque that much better than 140#?
/ Lug Nuts #20
My dad has a gooseneck trailer that had 3 mobile home axles under it when he bought it. I went to move a tractor for a friend and we were stopping at a stop light (luckily) and one of the tires rolled past us. My friend said you lost your spare, I said I don't have one. One of the axles broke right behind the hub. Chained it up and brought it home without moving the tractor. Dad bought two 8 lug axles and replaced them under it.
(7) Trailer Tires (A65640)
(7) Trailer Tires...
1992 CHEVY 1500 CUSTOM (A65643)
1992 CHEVY 1500...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
